Pro trans fluid #2901667
03/22/21 03:28 PM
03/22/21 03:28 PM
Staten Island, NY
RO23dave Offline OP
RO23dave  Offline OP
Staten Island, NY
Running a 727 pro trans, need to change the fluid, what recommendations as to best brand to use? I’ve been using amsoil super shift, type f, and, only a quart left from last batch. All insights gratefully accepted. Thanks in advance. Dave ss/ea #1355 fury
Re: Pro trans fluid [Re: RO23dave] #2901771
03/22/21 08:12 PM
03/22/21 08:12 PM
Winter Park, Florida
classracer Offline
classracer  Offline
Per Dave Smith " you have the trick tranny, you don't need the trick fluid. I use a brand name type F and change it every 15 to 20 runs. Good Luck....Jim
70 Challenger A/SA 2441
Re: Pro trans fluid [Re: RO23dave] #2901822
03/22/21 10:42 PM
03/22/21 10:42 PM
Valvoline Type F non synthetic twocents
If it starts to turn color or smell change it
Is this car a Street Hemi or M.W. car?
Stock type street and strip Pro Trans or one of his all out his race parts tranny?
Do you monitor and record tranny fluid temps?
If so once it gets near(290+F) or above 300F I change it in my S/P car with a glide in it shruggy
Re: Pro trans fluid [Re: Cab_Burge] #2901826
03/22/21 10:49 PM
03/22/21 10:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Petroleum Type F or FA. Valvoline. Change it frequently.
I've heard of all kinds of fluid being used in the big horsepower units - Pro Mod, RVW, Pro 275, etc - hydraulic oil, shock oil, compressor oil.... shruggy
Re: Pro trans fluid [Re: RO23dave] #2901838
03/22/21 11:27 PM
03/22/21 11:27 PM
SoCal
Brian Hafliger Offline
SoCal
I recommend LAT tranny oil...
Brian Hafliger
Re: Pro trans fluid [Re: Brian Hafliger] #2901880
03/23/21 06:51 AM
03/23/21 06:51 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
JR1 synthetic. Changed once a year at about 100 passes
Been running the same band and aluminum drum for over 500 passes. Both look like new. Clutch life is great. Motor makes around 900.
Doug
Re: Pro trans fluid [Re: RO23dave] #2901890
03/23/21 07:59 AM
03/23/21 07:59 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
I have had the best results with Penzoil type F non synthetic in my Proflite. SS/BM
Re: Pro trans fluid [Re: ValiantRich] #2901927
03/23/21 10:00 AM
03/23/21 10:00 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We used just about everything in our 727 over the years.
Store brand type F
Name brand type F
Dex/Merc
Universal trans fluid
TCI full synthetic
ATI 20W full synthetic
JD hydraulic fluid
Changed fluid and filter at the start of each season
And the list goes on. We put about 150 runs on a trans per season. The last 727 we ran for 6 seasons and it finally started to show signs of needing a rebuild (900 passes) We had all the good parts in it though. Billet steel drum, lightened sun shell, 2.10 straight cut gear set. roller bearings etc, etc, etc....
I guess my point is that the trans cared less about the type of fluid than it did about the quality of the parts and proper set up.
Re: Pro trans fluid [Re: cl440] #2901962
03/23/21 11:08 AM
03/23/21 11:08 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We use ATi20W in the Vettes Proflite
Re: Pro trans fluid [Re: RO23dave] #2901970
03/23/21 11:29 AM
03/23/21 11:29 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I used to use Mobil 1 Synthetic but for the past 10 years per the advise from my tranny builder I've been running O'Reilly's type F and every freshen up looks perfect. Told me to quit wasting my money. Run the whole year on same fluid, don't change engine oil all year either.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Pro trans fluid [Re: RO23dave] #2902101
03/23/21 04:11 PM
03/23/21 04:11 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Been running Dextron since the mid 80's. The trans was in my cuda from 2001-2006. The car was nothing special ran low tens. The trans sat for about 8 yrs when life got in the way. In 2013 took it in to be checked and rebuilt if nec was told other than a few minor adjustments everything was fine. Been running it ever since in my wagon. Its not as fast but is a heavy pig. Nothing but routine fluid changes.
Ok
Re: Pro trans fluid [Re: RO23dave] #2902113
03/23/21 04:53 PM
03/23/21 04:53 PM
Call Dave and ask him what they recommend now for your deal ,661-940-7400 scope
Re: Pro trans fluid [Re: WadeMetzinger] #2902224
03/23/21 11:35 PM
03/23/21 11:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ow there’s a man that’s smart
Re: Pro trans fluid [Re: WadeMetzinger] #2902310
03/24/21 10:43 AM
03/24/21 10:43 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Wade do you have aluminum drums?
Thanks,
Bill
Re: Pro trans fluid [Re: 340Cuda] #2902716
03/25/21 02:19 PM
03/25/21 02:19 PM
Tulsa, Ok
Tulsa, Ok
Thanks,
Bill
No, Steel billet drums in both my PG and 727.
Re: Pro trans fluid [Re: WadeMetzinger] #2903090
03/26/21 05:43 PM
03/26/21 05:43 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Dave told me to run Type F fluid in my ProFlite so I use Amalie Type F.
Re: Pro trans fluid [Re: SCDaytona] #2903353
03/27/21 12:10 PM
03/27/21 12:10 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
How often did he tell you to change it?
Do you have aluminum drums?
Re: Pro trans fluid [Re: 340Cuda] #2903369
03/27/21 01:17 PM
03/27/21 01:17 PM
With aluminum drums he use to say change it every 25 runs up
That is the main reason to think about buying and using a aluminum drum with a steel sleeve over the outside for the band to seat against upwork
Re: Pro trans fluid [Re: Cab_Burge] #2903370
03/27/21 01:36 PM
03/27/21 01:36 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I hate to say this because I am probably an idiot confused, but I run aluminum drums and I haven't changed my fluid in 25 years. And for at least the first 1/2 of those I raced every weekend.
