426 Hemi Auto Trans Dip Stick Length? #2901683
03/22/21 04:04 PM
03/22/21 04:04 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
Trying to confirm which dip stick I have for my 727. Does anyone know the correct length (overall and from tip to full line) for a stock '71 Hemi?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: RSI700VIPER] #2901723
03/22/21 05:45 PM
03/22/21 05:45 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I would think it would be the same as all the others 2466302 which supersedes to 4202951. I thought I had the length written down but I don`t have it at the moment. Edit, I read online people said it was 18 1/8 from tip to base and a ebay ad said it was 21-3/4" Overall
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: mopars4ever] #2901749
03/22/21 07:30 PM
03/22/21 07:30 PM
NW New Jersey
NW New Jersey
Mine is a 4202951 but when I search the part number, it comes up as a dip stick for a 383 - 440.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: RSI700VIPER] #2901753
03/22/21 07:41 PM
03/22/21 07:41 PM
VA
dragon slayer Offline
VA
Not sure of of yours but the 68-69 deep pan 6 qts is listed in this bulletin. 70 and 71 use a shallow pan but still 6 qts, so the stick may be different. 66-67 only had 5 quarts.
Attached PDF document
68 Hemi Dip Stick.pdf (51 downloads)
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: dragon slayer] #2901755
03/22/21 07:49 PM
03/22/21 07:49 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think he wants the numbers for the Torqueflight stick.
Joe
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: jlatessa] #2901770
03/22/21 08:10 PM
03/22/21 08:10 PM
blewbyu Offline
blewbyu  Offline
I have a 68 Hemi trans I can check if you think it would be the same.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: blewbyu] #2901788
03/22/21 08:49 PM
03/22/21 08:49 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Sorry, I found the correct part numbers for 426 in 70-71 as they are different from the others . 2538849 stick and 2892815 tube. 69 had those same part numbers for the 426 also.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: RSI700VIPER] #2901794
03/22/21 08:59 PM
03/22/21 08:59 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
RSI700, I know someone who can make you a new tube & dipstick assy - locking one too. This is all he does. Masta Performance - Dan Masta. He's a total Mopar guy too.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: Sunroofcuda] #2901803
03/22/21 09:22 PM
03/22/21 09:22 PM
NW New Jersey
NW New Jersey
Sunroof - Tube is installed and I'd rather not touch it. Just want to make sure I have the correct amount of trans oil in there. You can get pretty close with an engine oil change (drain pan and put 7 quarts in) but an auto has a converter and 2 coolers, etc. so draining the pan doesn't help with how much more to put in.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: RSI700VIPER] #2901815
03/22/21 10:23 PM
03/22/21 10:23 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Got ya. Good luck.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: dragon slayer] #2901895
03/23/21 08:42 AM
03/23/21 08:42 AM
NW New Jersey
NW New Jersey
That's a great image DS. Wish I could find something like that for a '71.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: RSI700VIPER] #2901916
03/23/21 09:39 AM
03/23/21 09:39 AM
VA
VA
That was my mistake, that is oil pan stick, not the transmission. Hard to believe actual info not available. Wonder why the stick would change though. Motor, manifold, trans the same, so you would think the routing and tube/stick would be the same.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: dragon slayer] #2901922
03/23/21 09:51 AM
03/23/21 09:51 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Mostly because of the different exhaust manifolds and the need to snake the tubes through or around
them probably??
Joe
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: jlatessa] #2901928
03/23/21 10:01 AM
03/23/21 10:01 AM
VA
VA
The manifold really did not change. I just went through the 66-71 parts book. The tube changed in 69 from the 66 2538846 to the 2892815. But the indicator never changed part number. Stayed 2538849. Tube probably changed from the bolt on style to the press fit style that mopar did, but the shape probably the same. If some one has an original hemi stick they could post a pic and measurement.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: dragon slayer] #2901974
03/23/21 11:33 AM
03/23/21 11:33 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
For comparison purposes I checked the dipstick from my 68 RR. I know the dipstick is not a repro. Not sure if this info applies for 71...
I measured from the cap to the end and got 16 3/4"
Cap to F mark is 14 3/4"
Cap to A mark is 15 3/8"
Overall from end to top of the curved handle is 18 1/2"
The dipstick was cut and has two rivets, this is approximately 4"-4.5" measured from the cap. The overlap is 3/4"
I do not see a part number on this dip stick.
Hope this helps.
Re: 426 Hemi Auto Trans Dip Stick Length? [Re: 68jim] #2902141
03/23/21 05:46 PM
03/23/21 05:46 PM
NW New Jersey
NW New Jersey
Hope this helps.
Excellent information Jim. I will check mine against yours. Mine definately has a part number as previously mentioned.
