Re: Maybe I was being to fussy with rods.
[Re: lancer493]
#2901556
03/22/21 11:37 AM
03/22/21 11:37 AM
Posts: 702 Southern Alberta
Uberpube
Southern Alberta
You are not being too fussy. A friend and fellow mechanic that I worked with nearly 30yrs had a saying,"there's always enough time to do it right the second time".Truer words were never spoken.I' ve just finished finalizing all clearancing except for 1, 2nd groove compression ring. It's on the way, thanks to a Summit employee willing to go the extra mile with the manufacturer, superceded part numbers, and getting it entered into the Summit system so it it can actually be ordered and shipped. I found just how much easier and quicker cast second rings file than the Hellfire nitrous top rings do. Lesson learned. Clearance right, sleep at night! Bill Were all your rings on the tight side in the pistons? I used icon 842's that came with the total seal ring package. Min spec is .0015 groove clearance, all the rings were a tight .0015 at 70 deg f.
[Re: lancer493]
#2901632
03/22/21 02:27 PM
03/22/21 02:27 PM
Posts: 109 Cottage Grove OR
WFO
Cottage Grove OR
You are not being too fussy. A friend and fellow mechanic that I worked with nearly 30yrs had a saying,"there's always enough time to do it right the second time".Truer words were never spoken.I' ve just finished finalizing all clearancing except for 1, 2nd groove compression ring. It's on the way, thanks to a Summit employee willing to go the extra mile with the manufacturer, superceded part numbers, and getting it entered into the Summit system so it it can actually be ordered and shipped. I found just how much easier and quicker cast second rings file than the Hellfire nitrous top rings do. Lesson learned. Clearance right, sleep at night! Bill So true, there's a similar saying in the fabrication world, "there's never enough time to do it right, but there's always enough time to do it again."
'65 Plymouth Sport Fury Blow thru twin turbo coming soon...
[Re: Uberpube]
#2901650
03/22/21 02:51 PM
03/22/21 02:51 PM
Posts: 16,925 NC
440Jim
NC
It took 2 full sets + 2 spares of rod bearings to get to it, but I got all 8 rods to .0024-.0026.
Its an eagle 4.250 crank and rods, all new, Were you using Clevite CB-743-HN and mixing with CB-743HXN? How many rods needed one of each to get your desired clearance? Did any use both halves of the HXN (extra clearance bearings)?
[Re: Uberpube]
#2901977
03/23/21 11:36 AM
03/23/21 11:36 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I mix STD and X bearings on most all my small blocks to get .0025 - .003 but for big blocks I typically use the full set of X bearings to get closer to .003 to .0035
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
