Do I Really Need to Change my Oil? #2901355
03/21/21 02:49 PM
03/21/21 02:49 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
I have a 2012 Ram, 4.7L, 20k miles.
I have driven 350 miles since my last oil change, 6 months ago.
I have changed the oil and filter every 6 months since new. I don’t use synthetic.
Will I void my lifetime drive train warranty if I wait a few more miles?
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901361
03/21/21 03:14 PM
03/21/21 03:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What does the warranty say on oil changes. If it says to then you had better do so.
Re: Do I Really Need to Change my Oil? [Re: NITROUSN] #2901371
03/21/21 04:18 PM
03/21/21 04:18 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
You do not need to! Oil does not go bad in six months. But as stated, if you have a warranty they may void it if you don't meet their respective limits, 6mo 3000 miles.
When you put the 350 miles on it do you get it up to operating temperatures?
My Monster are real!
Living within your means makes life pretty easy.
Re: Do I Really Need to Change my Oil? [Re: 67vertman] #2901377
03/21/21 04:39 PM
03/21/21 04:39 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
I drive very sparingly in the winter. When I do drive it, it normally gets up to temp.
While searching the internet, I ran across a discussion about 5 year inspections to maintain the lifetime warranty (on a 2009 Ram, I think). I have never heard of this.
There is nothing in my manual about the lifetime warranty.
Do I even have a warranty anymore?
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901382
03/21/21 05:01 PM
03/21/21 05:01 PM
5thAve Offline
5thAve  Offline
I'm in the same position with one of my vehicles. It didn't get an oil change last year but because of the pandemic it was probably only driven a couple hundred miles since it's previous oil change anyway.
Look at what came with the truck for the warranty.
I don't know how that Chrysler lifetime warranty worked but for most of them they won't cover a repair that exceeds the value of the vehicle so at that age you might not have to worry anyway.
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901384
03/21/21 05:05 PM
03/21/21 05:05 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
My thought is that you never had a lifetime warranty on the mechanical parts. If you bought your truck new they would have told you, or tried to get you to by am extended warranty, typically it 5 years 50,000 miles which ever comes first, for manufacture warranty.
Stay with your plan to change the oil filter, every six months, and wait on the oil change.
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901391
03/21/21 05:23 PM
03/21/21 05:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
Do I even have a warranty anymore?]
You were the one that said you had a lifetime warranty. What paper work did you get when you bought it new? You should have the warranty guide with your owners manual. My 2015 Power Wagon had a 5 year 100,000 mile power train. I purchased a unlimited mileage lifetime extended warranty/service contract. I have paper work on both. So if you did not buy an extended lifetime warranty , your warranty most likely expired 5 years from the in service date. So basically you are on your own now. In my opinion keep doing what you have every 6 months change it.
Re: Do I Really Need to Change my Oil? [Re: NITROUSN] #2901405
03/21/21 06:32 PM
03/21/21 06:32 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
It appears I am mistaken.
I remember talk about the lifetime powertrain warranty coming standard when I bought my truck. While discussing forgoing the extra cost warranty with the salesman and advertising at the time.
I have nothing in writing so I guess I really don't have any warranty anymore.
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901417
03/21/21 07:23 PM
03/21/21 07:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Your dealer can run your VIN and tell you for sure whats on it for warranty.
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901419
03/21/21 07:25 PM
03/21/21 07:25 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Quote
You can look on the original buyers order or any other purchase documents to see whats noted.
Re: Do I Really Need to Change my Oil? [Re: NITROUSN] #2901422
03/21/21 07:41 PM
03/21/21 07:41 PM
Shawnee, KS
AZ67Dart Offline OP
AZ67Dart  Offline OP
Shawnee, KS
It is strange after 9 years to realize that I imagined it all.
It looks like my truck came with a 5 year/100,000 mile powertrain warranty.
I think I will go to a yearly, about 2000 miles, oil and filter change schedule.
Even with non-synthetic oil, that should be plenty, right?
I think I will change the schedule on my 60k mile 2014 V6 Chrysler 300 to yearly as well. That will about every 4000 miles.
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901423
03/21/21 07:46 PM
03/21/21 07:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Personally I would still go twice a year Oil and filter..
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901429
03/21/21 08:22 PM
03/21/21 08:22 PM
Guitar Jones Offline
Chrysler did have a lifetime powertrain warranty for a short time. I don't recall the specifics of it but it did require a periodic inspection. Have a dealer run your VIN and see what you have.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Do I Really Need to Change my Oil? [Re: Guitar Jones] #2901459
03/21/21 10:51 PM
03/21/21 10:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Warranty’s are a scam, you have to do the dealer ‘servicing’ some are thousands of dollars a year just to keep your warranty. My 15 SRT Challenger just ran out of years (extended) (it has 21,000 miles) they wanted $3100 to extend another 3 years. Nope wont do that, I’m putting $200 into an account each month, $2400 after the first year, 2 years ($4800) should cover any major problems. If I don’t use the cash it’s still mine not out the window to them.! BTW my oil had to be changed every 12 months (which I don’t, it’s at 5000 miles) never heard of 6.
Re: Do I Really Need to Change my Oil? [Re: AZ67Dart] #2901680
03/22/21 03:56 PM
03/22/21 03:56 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
No. This has been beat to death on here and elsewhere.
I have trailer queens with oil 15, 18 years old and maybe 500 miles on them. Oil is still clean, I'm not changing them any time soon. No issues. I have beaters that maybe get an oil change every 20,000 miles, and for whatever reasons: zero issues.
It's been in the ground for millions of years, it can be in your oil pan for a million more if it's not getting used. Oil does not "break down".
You can believe the Snake Oil commercials all you like, but I'm sure not going to dump perfectly good (and expensive) oil on my neighbors' lawn.
Mo' Farts
Moderated by "tbagger".
Re: Do I Really Need to Change my Oil? [Re: Grizzly] #2901746
03/22/21 07:17 PM
03/22/21 07:17 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Well, to a point. Oil does pick up contaminants as time and miles roll on, especially with vehicles that only see short trips and often don't reach operating temps for long enough periods of time to burn off the contaminants. If your vehicle runs for 30 minutes after it reaches operating temp, the oil will last a long time. If it only runs 10 minutes at a time and gets shut off for hours afterwards, the oil picks up a lot of junk the can damage your engine, you need to change the oil and the oil filter.
Also, the oil itself does not break down, but the additives in the oil can. As the additives in the oil break down, it can cause engine wear, how much additional wear may be subject to question. Will there be enough wear to cause an engine failure? Don't know. Most engines are designed to run a lot of miles, but some don't last nearly as long as others of the same design, why is that? Gene
Re: Do I Really Need to Change my Oil? [Re: poorboy] #2901833
03/22/21 11:14 PM
03/22/21 11:14 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If you are really going to lose sleep over oil with a few hundred miles on it, pull an oil sample and then fill up a new filter and spin it on. Send the sample out and follow their recommendations for change intervals. They monitor acidity and moisture levels as well as fuel dilution etc. The make up oil you add/fill the new filter with will more than keep your additive package current.
Kevin
Re: Do I Really Need to Change my Oil? [Re: Twostick] #2902086
03/23/21 03:25 PM
03/23/21 03:25 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I’m interested in seeing what ‘junk’ gets in these sealed up engines of today.
Re: Do I Really Need to Change my Oil? [Re: cudaman1969] #2903118
03/26/21 06:48 PM
03/26/21 06:48 PM
The junk comes from the burnt fuel and a small amount from the environment. While engines are better sealed today they still have fresh air intakes for both combustion and crankcase ventilation.
