Re: Source for 360 bare block ?
[Re: AndyF]
#2901346
03/21/21 02:30 PM
03/21/21 02:30 PM
Posts: 20,193 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lots of 360 blocks out there from 50.00-350.00 if you start looking. Stock 360 cast cranks are plenty strong enough to produce some amazing ET’s at the track.
[Re: lostdog]
#2901844
03/22/21 11:49 PM
03/22/21 11:49 PM
Posts: 5,335 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Not sure if the junkyard core I have is going to be buildable so I’m preparing myself for buying a new block to do the 360 based stroker
I already have Trick flow heads and intake Using Harland sharp 1.5 rockers Howard’s cam 600/600 245/253@ .050 Will be using steel crank, H beam rods forged pistons (10.5:1)
I’m hoping I could get a decent NEW SEASONED block for $1000 or so.
Where do you guys suggest is a good source for the block.
Thanks! Your words about "new seasoned block" seems to be a contradiction. A seasoned engine is one that has been cycled, through years of use, with heating/cooling down cycles. Any 360 engine block you come across will be a "used" block.
Plymouth Makes It!
[Re: AndyF]
#2901856
03/23/21 12:51 AM
03/23/21 12:51 AM
Posts: 9,525 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
I think the only "seasoned" new block would of been the X and very very early plain lettered R blocks.
Look for a early-mid 70s motor junked motor home or B van with a 360 with say 40k miles, there is the "seasoned" block your wanting.
Then get ready for the sticker shock on the block machine work, good work is not cheap these days and you will have at least or more then 1k in buying core and having a good shop do all the proper machine work and fixing any tiny stroker kit or ootb head issues.
STOP POTATO HATE!
