Hard start when below freezing #2900484
03/18/21 06:28 PM
03/18/21 06:28 PM
Byron, NY
W.I.N. Racing Offline OP
Byron, NY
I have a 2005 Magnum RT, It has some minor mods, TB spacer, shortie coil wires, Shortie headers.Borla exhaust, Fresh air kit, 165deg Therm and a Diablo Tuner set to max performance. It runs great no complaints on running
Im having a progressive problem that when the ambient temp is 0-20deg F it simply wont start, 20-30 just hard to start. It cranks over fine but pops and farts in the pipes. Once it does start, you can tell it was flooded. I have found if I take a hair drier and place it under the engine cover for 5-10 min it starts up. and once it starts it runs fine. So I have replace the plugs, Used inj cleaner, Installed a new battery, cleaned the TB. and given a good once over for potential causes. any body have a similar experience?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hard start when below freezing [Re: W.I.N. Racing] #2900642
03/19/21 09:34 AM
03/19/21 09:34 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Codes? Monitor coolant temperature with a scanner and verify correct fuel pressure.
Re: Hard start when below freezing [Re: NITROUSN] #2900738
03/19/21 01:40 PM
03/19/21 01:40 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I can't remember if there's an ambient air sensor on those. If there are, you may want to look into this
Re: Hard start when below freezing [Re: moparjim79] #2900965
03/20/21 06:37 AM
03/20/21 06:37 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would look at intake air temp and coolant temp on a scanner to verify they are reporting the cold correctly.
If that all looks fine you might try loading the stock tune back into it, if that fixes it call diablo.
68 Barracuda Formula S 340
