Ebody hemi booster offset bracket #2899855
03/16/21 08:33 PM
03/16/21 08:33 PM
Ont, Canada
moparo Offline OP
moparo  Offline OP
Ont, Canada
Is there any one making these brackets?
performancecarrestorations.com
Re: Ebody hemi booster offset bracket [Re: moparo] #2899899
03/16/21 10:44 PM
03/16/21 10:44 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Re: Ebody hemi booster offset bracket [Re: 469runner] #2899995
03/17/21 09:58 AM
03/17/21 09:58 AM
VA
dragon slayer Offline
VA
The only difference between B and E is the petal center link length. Not sure many are reproducing these anymore. They are using the generic one I think with the smaller booster bolt pattern. If you find one make sure it has the pattern of the booster you are using.
Re: Ebody hemi booster offset bracket [Re: moparo] #2900016
03/17/21 11:10 AM
03/17/21 11:10 AM
WV
Little Detroit Offline
WV
the repro booster bracket leaves a lot to be desired
Re: Ebody hemi booster offset bracket [Re: dragon slayer] #2900042
03/17/21 12:30 PM
03/17/21 12:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I use to repro both brackets years ago, not anymore....IIRC DrDiff also offers both sized brackets
MikeG
Re: Ebody hemi booster offset bracket [Re: DAYCLONA] #2900112
03/17/21 03:41 PM
03/17/21 03:41 PM
A727Tflite Online content
A727Tflite  Online Content
I’ve been soaking my bracket for over a month now. Used heat and a press.
Can’t get the pin with square head out of the bracket. It’s the one on the far right in the picture.
Anyone have a pin or does anyone offer them new before I start making one ?
