Clover leaf removal Indy intake
#2899843
03/16/21 08:03 PM
03/16/21 08:03 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I am just wondering if any one is cutting the clover leaf out of the top of a 4500 Indy intake. At this point I cannot afford to send it out to be professionally done but i am more than willing to do it myself if there is an improvement.
Any real world experience would be good,
451 cubic inch b engine that will be run on the throttle stop in super street.
Thank you
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
Re: Clover leaf removal Indy intake
[Re: 451Guy]
#2899851
03/16/21 08:22 PM
03/16/21 08:22 PM
Posts: 12,384 Taxes & Virus's R-US, NY
Dragula
Yes. Remove it. Makes a big difference at 512 cubes on a Low deck! Removed it myself and re-blended everything.
[Re: Dragula]
#2899854
03/16/21 08:32 PM
03/16/21 08:32 PM
451Guy
Alberta, Canada
I also see that you cut back the dividers. Looks really good!
Thanx 451 Guy
[Re: 451Guy]
#2899939
03/17/21 01:20 AM
03/17/21 01:20 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
Which version of the Indy 400-3, early or late? Individual injector bosses or two per boss?
[Re: Cab_Burge]
#2899944
03/17/21 01:41 AM
03/17/21 01:41 AM
451Guy
Alberta, Canada
Mine has the two bosses on each pad.
Thanx 451 Guy
[Re: mopar dave]
#2899969
03/17/21 08:13 AM
03/17/21 08:13 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have no back to back tests or anything, but everyone I've talked to that makes power w/ them said to get rid of it...so I did just that on my Indy 426-4 hemi manifold and the 440-3 on my wedge. The old 426-3 manifold I used to have that was ported by Indy for Mike Daurity's KOS car also had the cloverleaf removed.
[Re: an8sec70cuda]
#2899976
03/17/21 08:34 AM
03/17/21 08:34 AM
Posts: 8,031 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I have no hard data either, but Wilsons suggested i remove the cloverleaf and put a 4 hole tapered spacer on top so i did. With a couple other improvements i did pick up 3.5 tenths and 3.5mph next time out.
[Re: mopar dave]
#2899980
03/17/21 09:04 AM
03/17/21 09:04 AM
Posts: 10,021 MN
JERICOGTX
MN
Anyone have data on how much this mod only helps? It can be dyno numbers. or ET.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2900000
03/17/21 10:20 AM
03/17/21 10:20 AM
Dragula
I ran mine back to back, before and after porting....It was worth .07 in the 1/8th on my 512 low deck. I think its especially important on the low deck intake. I think that intake has less plenum than the RB intake.
[Re: JERICOGTX]
#2900031
03/17/21 11:53 AM
03/17/21 11:53 AM
Posts: 30,998 Oregon
AndyF
Anyone have data on how much this mod only helps? It can be dyno numbers. or ET. My 470 picked up a significant amount of power after Wilson ported the Indy intake. As cast, the Indy intake was very rough and the port sizes were inconsistent. I also did not like the way the plenum looked but I'm not a porting expert so I didn't touch it. Wilson removed most of the cloverleaf and then lengthened two of the dividers by welding on extensions.
[Re: 451Guy]
#2900044
03/17/21 12:32 PM
03/17/21 12:32 PM
Cab_Burge
Mine has the two bosses on each pad. I've own both styles,, the later one with a common boss doesn't have the dividers protruding into the plenum as much as the earlier ones is what I remember. I haven't done any work on the dividers on any of the 400-3 or 440-3 intakes I've used, I did notice the differences though I'm sure Indy didn't make those changes for no reasons, especially after seeing what Wilson did to Andy late style Indy 400-3 intake
[Re: 451Guy]
#2900050
03/17/21 12:53 PM
03/17/21 12:53 PM
Dragula
Mine has the two bosses on each pad. Mine had them on it, as its only 2 years old....I removed them and the Indy logo. Again, I couldn't help myself.
[Re: Dragula]
#2900075
03/17/21 01:42 PM
03/17/21 01:42 PM
451Guy
Alberta, Canada
Mine appears to be the same intake as Andys minus the Wilson Touch!!!!!!!
I have had it for years so I am assuming it is the old style. Am I correct?
Thanx 451 Guy
[Re: 451Guy]
#2900088
03/17/21 02:35 PM
03/17/21 02:35 PM
Cab_Burge
No, his is a new style with the single oval EFI boss connecting across on both runners, the early ones had two raised individual bosses, one on each runner
[Re: Cab_Burge]
#2900105
03/17/21 03:25 PM
03/17/21 03:25 PM
451Guy
Alberta, Canada
Thanks Cab. I guess mine is the new one then.
I really appreciate the comments. I am thinking there is going to be some aluminum filings in my future.
Thanx 451 Guy
[Re: 451Guy]
#2900114
03/17/21 03:46 PM
03/17/21 03:46 PM
Posts: 4,206 New York
polyspheric
New York
Years ago, I saw an intake flange matching the throats above it on its upper surface, but it had only the bottom of the flange flared/radiused out (using the largest curve for the thickness of material) but each corner was radiused away from itself - toward the other corners. Why? Did it work?
Boffin Emeritus
[Re: polyspheric]
#2900220
03/17/21 10:41 PM
03/17/21 10:41 PM
451Guy
Alberta, Canada
Well its offical! I am pot committed now. Put cut off wheel to aluminum amd the clover leafs are gone. Going to be an interesting project!
Thanx 451 Guy
[Re: 451Guy]
#2900284
03/18/21 09:23 AM
03/18/21 09:23 AM
Posts: 4,045 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Completely cutting ALL runner dividers IS NOT the way to correctly modify this manifold. However, some lengths could use adjustment. This is a manifold that worked really well AND it fixed the distribution issues inherent. I was only 'allowed' an evening to work on this so, it isn't 'done' ...I'd have cut away some of the clover at the flange among a few additional asthetic improvements. ( another 2-3 hours work?)
