Re: RV2 AC Compressor or new style rotary . . .
[Re: a12rag]
#2897354
03/09/21 12:27 PM
03/09/21 12:27 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
If it ain't broke don't fix it....
Or my favorite, if it ain't broke, you're not trying!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: GTSDart340]
#2897357
03/09/21 12:36 PM
03/09/21 12:36 PM
Posts: 10,766 North Dakota
6PakBee
North Dakota
I am just too much of an anal purist. I'd stick with the original. The only thing I would question is if the shaft seal is compatible with R-134A.
[Re: a12rag]
#2897376
03/09/21 01:33 PM
03/09/21 01:33 PM
Posts: 3,396 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
If it was working and my engine bay was as pretty as that one--no way I would tear it apart to fix some thing that wasn't broken.
If it starts to go, then maybe I would look at some options.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: a12rag]
#2897440
03/09/21 05:14 PM
03/09/21 05:14 PM
Posts: 26,009 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Keep in mind that you need to install a clutch cycling switch if you use other than the RV2 compressor.
[Re: BDW]
#2897500
03/09/21 08:23 PM
03/09/21 08:23 PM
Posts: 5,960 ohio
ruderunner
ohio
If I had a functional RV2 setup, I'd simply repair it.
Especially on a driver or cruiser.
If I was building from scratch a full function touring car I would go newer. But that would be accepting that everything is going to be custom.
Angry white pureblood male
[Re: BDW]
#2897556
03/09/21 10:20 PM
03/09/21 10:20 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
[quote=John_Kunkel]Keep in mind that you need to install a clutch cycling switch if you use other than the RV2 compressor. [/quote
Why is that?] The system will freeze up. The RV2 has a valve that keeps that from happening.
[Re: Alchemi]
#2897599
03/10/21 01:07 AM
03/10/21 01:07 AM
Posts: 2,926 Calgary, Alberta Canada
a12rag
The RV2 will pump more gas than the sanden by a reasonable percentage, leave it alone...
Is that a propane converter behind the battery? No, that factory cruise control transducer
[Re: 6PakBee]
#2899651
03/16/21 12:01 PM
03/16/21 12:01 PM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
Shaft seals on AC Compressors are not lip seals like you would see on a low pressure seal like a main seal. They are a type of seal that looks a lot like the seamless ring seals in a transmission. They should be R134a resistant because they are not rubber. Side note: Never handle a compressor seal with your hands. According the manufacturers, it ruins them. I have converted a lot of systems over to R134a and I have not had a leak at the compressor shaft seal. All have leaked down over time much faster than an R12 system would. It may be the smaller molecules escaping through the hoses not designed for R134a or the fact that R134a tends to run higher pressures and the result is small leakage. Mineral oil was used in R12 systems. Mineral oil will not carry in R134a so it settles in the bottoms of the compressor, drier, and cores. So you will need to change the oil or at least run Ester oil. PAG and Mineral oil are not compatible together. Fill your system by pressure not the quantity, books will tell you 80% R134 to what the original R12 system used but that is usually too much. Pressures are temperature dependent. All that said I have no problem using the old system if I want it to look stock but it will never cool as good as a properly functioning R12 system. If you want the absolute best using R134a gas, then install a matched component system made for R134a. My ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: IMGTX]
#2899742
03/16/21 03:24 PM
03/16/21 03:24 PM
Posts: 1,850 South Bend
John Brown
South Bend
Around here, little cans of R12 go for about $20 each. Seems like no big deal unless you have a leaker.
[Re: cudaman1969]
#2899774
03/16/21 04:56 PM
03/16/21 04:56 PM
a12rag
Can you still drive into Canada or Mexico and get it recharged with R12? Asking for a friend I am in Canada . . . and it's all R134 up here, as far as I know. When I put the car together, all AC components were NEW, with R134 compatible hoses, seals, etc . . .
[Re: ruderunner]
#2901004
03/20/21 09:21 AM
03/20/21 09:21 AM
DaytonaTurbo
Manitoba, Canada
If I was building from scratch a full function touring car I would go newer. But that would be accepting that everything is going to be custom. Same here. A scratch build would see (you would have to squint) a sanden mounted under the alternator where the fuel pump used to be.
[Re: DaytonaTurbo]
#2901033
03/20/21 11:49 AM
03/20/21 11:49 AM
Posts: 1,017 rust belt
Moparite
rust belt
Propane is an excellent refrigerant. It's just against the law to use it in a car, but so is speeding and they don't have a radar gun for propane. LOL stirthepot Ever wonder why it's against the law? Propane is highly flammable and anything that breaks a line and can ignite it then you have a fireball under your hood! R134 uses a higher operating pressure than does R12. So if the time comes where you might need to do some work to the ac system it's wise to use a compressor that is made for 134a. If you have a 6 pack or hemi the choice is simple because you don't have the option.
