Re: Encroachment issue/property line
[Re: varunner]
#2899350
03/15/21 01:21 PM
03/15/21 01:21 PM
Posts: 12,802 East Bay, N. Cal.
calmopar
East Bay, N. Cal.
Hate to say it. Attorney, lawsuit, court will compel him to fix it.
Trying to enjoy life!
[Re: calmopar]
#2899354
03/15/21 01:29 PM
03/15/21 01:29 PM
Posts: 3,385 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
I'd get a survey done (will likely have to be done on your dime). Then call a layer that specializes in real estate stuff.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: varunner]
#2899365
03/15/21 02:02 PM
03/15/21 02:02 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Do you have a plat already? I’d show him and see if he will be reasonable. I’ve had it out with neighbors over such things and it can get ugly quick. You need to get a survey done it sounds since he moved the pin. I’d get that booked ASAP will trying to confront him with what you have now. If he’s a jerk, and you feel it’s on your land/survey proves it, you could escalate and take out the driveway gift he gave you just the same as he did to you putting it there. Depends on how you want to play it. I once planted a decent sized tree where a driveway was installed on my property. That got the message across on that one. Others got nasty when I got sick of the bs and put up a fence.
I want my fair share
[Re: varunner]
#2899367
03/15/21 02:03 PM
03/15/21 02:03 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Do any of you all have any experience with this. My son has building lot in a subdivision that on the lot next door, a contractor has moved the property line marker at the edge of the street in a ditch ( a steel rod ) about 10 feet and put in a additional length of culvert. So now his driveway goes onto our lot. I think this is easy to prove with a survey, but my question is if he doesn't want to fix this, how do you force him to fix it. We've called him and so far no response. The local zoning dept is no help. Thanks in advance. How long has this been going on? Depending on your locale be mindful of adverse possession which may have well been their intent. Often the time since he has been using it is factored into whether it now belongs to him.
[Re: varunner]
#2899373
03/15/21 02:14 PM
03/15/21 02:14 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Do any of you all have any experience with this. My son has building lot in a subdivision that on the lot next door, a contractor has moved the property line marker at the edge of the street in a ditch ( a steel rod ) about 10 feet and put in a additional length of culvert. So now his driveway goes onto our lot. I think this is easy to prove with a survey, but my question is if he doesn't want to fix this, how do you force him to fix it. We've called him and so far no response. The local zoning dept is no help. Thanks in advance. First things first, is the "property line marker" an official property survey pin that marks the lot line? If it is, get a copy of your local Planning and Zoning ordinance. Typically there is a section in most that prohibits removal of a property pin. In this case as removal would be a criminal matter, you file a complaint with the PD and the situation should be taken care of. If the "property line marker" was not an official property pin, then it gets stickier. In this case if you feel that the adjoining lot is encroaching on your lot you will have to have a survey performed to determine the lot boundaries and if the encroachment is occurring. If after a survey the encroachment is real, then unless there is a remedy in the Planning and Zoning ordinance, civil court is your only option. The reason I mention a remedy in the Planning and Zoning ordinance is that in my one horse town, if your neighbor installs a fence on your property, that is a violation of the ordinance and can be enforced by the PD as a criminal matter.
[Re: varunner]
#2899374
03/15/21 02:20 PM
03/15/21 02:20 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The local zoning dept is no help. No help? You're a taxpayer, they work for you. I suggest you become a "squeaky wheel".
[Re: varunner]
#2899412
03/15/21 04:47 PM
03/15/21 04:47 PM
6PakBee
North Dakota
This all has been just discovered. We're planning building on our lot in the next month or 2. The lot in question has a modular home which has just been installed. The contractor isn't finished yet but will soon be. We just noticed what happened yesterday. The property marker (steel rod ) marks the corner of our lot and the other. Once we talk with the contractor, we should quickly find out how this will play out. I need to find out what law or county reg is being broken by moving the pin. This is in gloucester co. va We're attempting to contact the owner of the company and not whovever is working on the house. Absolutely. You have to be on firm ground before you come out swinging.
[Re: 6PakBee]
#2899424
03/15/21 05:14 PM
03/15/21 05:14 PM
Posts: 1,840 South Bend
John Brown
South Bend
Buy a copy of the zoning ordinance. If they don't sell them, ask them to make you a copy of the original. I have had zoning office employees tell me it would be expensive. Asked how expensive, they said ten cents a page. I asked how many pages it would be. When they told me twenty pages, I told them I could afford the two dollars. Zoning boards often hate to give you information you need. Don't let them get away with it. I have gotten zoning maps and full copies of zoning ordinances everywhere I rented or owned property. They work for you, even though they think they don't.
[Re: John Brown]
#2899436
03/15/21 05:28 PM
03/15/21 05:28 PM
Posts: 2,522 God's Country Maryland
GODSCOUNTRY340
Start taking pictures of the corner from the north, east, west and south. Pics of the marker he moved and where it was moved from. Judges like seeing lots of pictures, they can make or break the case.
[Re: varunner]
#2899446
03/15/21 06:11 PM
03/15/21 06:11 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
Do any of you all have any experience with this. My son has building lot in a subdivision that on the lot next door, a contractor has moved the property line marker at the edge of the street in a ditch ( a steel rod ) about 10 feet and put in a additional length of culvert. So now his driveway goes onto our lot. I think this is easy to prove with a survey, but my question is if he doesn't want to fix this, how do you force him to fix it. We've called him and so far no response. The local zoning dept is no help. Thanks in advance. have a survey company come out and mark the corners. then you can defend whats yours without any questions. they will be trespassing from that point forward. post it and enforce that.. after you do this, you can try the friendly way first.....
[Re: varunner]
#2899467
03/15/21 07:16 PM
03/15/21 07:16 PM
Posts: 12,158 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I would be reading the easement, too. Just in case.
The formal survey and attorney may be your only real route if the neighbor doesn't want to keep it friendly.
Master, again and still
