recommend SBM tall valve covers #2899315
03/15/21 12:09 PM
03/15/21 12:09 PM
Montgomery, TX
jhugCUDA Offline OP
jhugCUDA  Offline OP
Montgomery, TX
Need recommendations for small block Mopar "tall" valve covers that clear Comp Cams adjustable rockers on Edelbrock RPM heads. Prefer cast aluminum/fabricated aluminum with holes and baffles. Doesn't need to be anything fancy; its going in a drag car.
Also, would like warnings on valve covers to avoid (and why).
I purchase the Summit # 440421 valve covers, but they weren't tall enough.
Thanks.
Re: recommend SBM tall valve covers [Re: jhugCUDA] #2899318
03/15/21 12:14 PM
03/15/21 12:14 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I have the Mopar Performance cast valve covers on 2 of my cars. One has Edelbrock heads and 273 rockers, other has Trick Flows with Mancini Racing 1.6 rockers. They clear everything just fine. I use them with the rubber with steel core valve cover gaskets and they work great. Not sure Mopar makes the valve covers anymore but might be able to find a used set.
Re: recommend SBM tall valve covers [Re: DusterKid] #2899321
03/15/21 12:17 PM
03/15/21 12:17 PM
Montgomery, TX
jhugCUDA Offline OP
jhugCUDA  Offline OP
Montgomery, TX
thanks for the input.
Re: recommend SBM tall valve covers [Re: jhugCUDA] #2899483
03/15/21 07:49 PM
03/15/21 07:49 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might also look to see if anyone is making spacers wink
Re: recommend SBM tall valve covers [Re: TJP] #2901265
03/21/21 09:29 AM
03/21/21 09:29 AM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
there is a guy on FeeBay that makes spacers for many engines. Billet aluminum. Just got a set for a Magnum 360. the guy's Ebay name is something like "RSDan29".
