The Dart has been off the road since fall of 2012, but it finally has new paint (EE1). Back in '95 it had some patch panels put on the quarters, as well as glass fenders, and repainted the original Sunfire Yellow. I never bothered to cut holes for the side marker lights (all about less weight back then). The new AMD quarters and fenders have the holes, so now I need side marker lights to replace the long-gone pitted originals.
The front and rear wiring harnesses for the marker lights are different (as shown in pics, and the old spec sheet), but the reproduction sets i see for sale show the ambers and reds with the same male-end connector. Question..are there any sets available with the correct rear lights that work with the original wiring? Or does the rear wiring harness need to be replaced with a female connector?
Question on the front wiring harness...My weak memory says that the yellow end connects to fender mounted blinkers, correct??
Thanks!!
