67 Belvedere II - strong gas smell after filling tank
#2898707
03/13/21 11:58 AM
03/13/21 11:58 AM
Posts: 701 Northern California
lilcuda
Northern California
My ‘67 Belvedere II gets a strong gas smell after I add fuel. I made sure not to overfill it. I had done this in the past and fuel leaked on the ground, so after driving it a bit, I let it sit outside so any residual gas could evaporate. Yesterday I added about $20 worth of gas to go to a cars and coffee this morning. I made sure I didn’t spill any and I stopped short of filling up all the way, but all last night, the garage stank of gas. Still does this morning.
Any idea what’s going on?
There are no puddles or evidence of leaks.
Thanks.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
Re: 67 Belvedere II - strong gas smell after filling tank
[Re: lilcuda]
#2898777
03/13/21 02:48 PM
03/13/21 02:48 PM
Posts: 18,419 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I had done this in the past and fuel leaked on the ground Well you need to find where it is leaking? You already have the clue. Rusty tank, bad filler tube, Filler tube or sending unit seal. Vent line off. Open port on an aftermarket tank. You need to add fuel until the leak is showing and that should tell you what needs to be done.
[Re: lilcuda]
#2898794
03/13/21 03:58 PM
03/13/21 03:58 PM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
Check to see if the filler tube to tank rubber seal is leaking any.
On the 67 Satellite that I had several years ago when I installed TTI tailpipes and the factory tailpipe hanger brackets I had to push the gas fill tube just a little to clear and it started a very slight leak at the filler tube seal which had gotten hard over the years.
A new filler tube tank seal cured it.
The filler tube also is part metal tube and part rubber hose, so check it for any cracking.
[Re: SNK-EYZ]
#2898809
03/13/21 05:35 PM
03/13/21 05:35 PM
Posts: 10,717 North Dakota
6PakBee
North Dakota
The '66-'67 B-bodies are notorious for this. There are two small rubber 90 degree hose elbows for the vent and one large rubber 90 degree hose elbow for the filler tube. In addition to the seal grommet in the tank for the filler tube, there is a small grommet in the tank for the vent. One or more of these are leaking. The vent elbows, filler elbow, and filler grommet are all in repop. But if you are unlucky enough to have the vent tube grommet leaking, buy a new tank. I know of no way to successfully replace this. The repop tanks do not have this grommet and I can't understand why Mopar didn't use this approach to start with.
[Re: 6PakBee]
#2898813
03/13/21 06:13 PM
03/13/21 06:13 PM
lilcuda
Northern California
Sorry, I forgot to mention that the tank was replaced prior to me buying the car. I took a look at those rubber hoses ( what I could see from under the car) and they looked dry. I’m now thinking it might be the sending unit gasket. I need to jack up the car and investigate.
[Re: lilcuda]
#2898960
03/14/21 10:28 AM
03/14/21 10:28 AM
6PakBee
North Dakota
Sorry, I forgot to mention that the tank was replaced prior to me buying the car. I took a look at those rubber hoses ( what I could see from under the car) and they looked dry. I’m now thinking it might be the sending unit gasket. I need to jack up the car and investigate. Two things, first, you mention the hoses looked dry. Is there any evidence of gas staining on either? If they are leaking they won't be wet very long. If there is no evidence of staining, then I would agree with your thought of it being the sending unit. Second, the repop locking rings I've seen for the repop '66-'67 sending unit seem to be shorter than the OEM and doesn't clamp down as well. I've been cleaning and reusing the original rings.
[Re: lilcuda]
#2899106
03/14/21 05:55 PM
03/14/21 05:55 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Thanks.
If you added $20, that's not a lot. Without any puddles or drips, the smell will have to be vapor or a small leak.. IIRC, the float gauge flange sits most of the way up the back side of the tank at an angle. It could be that when you put $20 of gas in it, the level could reach the gasket there and start weeping out, until you use some gas and the level drops below the gasket. .. Gas could weep out around the gasket giving you the smell but no drips or puddles. My '67 has never done that. Knock on wood. - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
