NASA reveals what exploded over Vermont scary to say the lea #2898320
03/12/21 12:27 AM
03/12/21 12:27 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
What exploded over Vermont last weekend was estimated to be equivalent to 440 pounds of TNT...........the scary part is the size and mass of the object that rocked part of the State was only 10 lbs weight and 6 inches in size. Oh and it never hit the earth and was about 30 miles up when it exploded. Now I can believe what they say was huge that did in the dinosaurs dino frown bawling
We're in big trouble if a really big one finds us............again panic pleasant dreams wink
https://www.msn.com/en-us/news/tech...loded-over-vermont-this-week/ar-BB1evddY
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: A12] #2898325
03/12/21 12:52 AM
03/12/21 12:52 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
As screwed up as this country (world?) is right now, it might be an improvement.
Interesting read though.
John
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: A12] #2898365
03/12/21 10:35 AM
03/12/21 10:35 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
F=MV^2. When the V is 12 miles per second, it doesn't take much M to F up your day.
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: SattyNoCar] #2898368
03/12/21 10:47 AM
03/12/21 10:47 AM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
Originally Posted by Satilite73
it WILL be an improvement.
Fixed.
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: BSharp] #2898380
03/12/21 11:19 AM
03/12/21 11:19 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
iagree
I remember vaguely a IMO useful example, which would you rather be struck by ( the numbers here are out of thin air, but the intended point remains valid I believe),
which would you rather be struck by, 100,000 ton ocean freighter going 25mph, or a 100,000lb Concorde jet doing 1500 mph?
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: A12] #2898386
03/12/21 11:32 AM
03/12/21 11:32 AM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
There has got to be a little more to the story than just your ordinary average little meteorite created a huge blast hitting the earth's atmosphere. Meteorites, chunks of asteroids and even human made space debris bigger than the rock in question hit our atmosphere every day.
In fact, I have a 6" meteorite that weighs around 10# here on display at my house and I'm not aware it made headlines when it made its way here?
What was unique about this one that made it explode with such force? Is there an angle where it hit the atmosphere "just right" that created this phenomena?
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: Mastershake340] #2898410
03/12/21 12:19 PM
03/12/21 12:19 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Yours (a nice one) looks like iron which partially melts on its way down, where a rocky meteor is probably more likely to explode.
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: Mastershake340] #2898412
03/12/21 12:20 PM
03/12/21 12:20 PM
hooziewhatsit Offline
42.000 miles per hour (19 kilometers per second).
Stuff in low earth orbit is moving at 7.8km/s. This was moving a bit over twice as fast as that. And probably came in at a steeper angle too.
big-badda-boom
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: hooziewhatsit] #2898483
03/12/21 03:19 PM
03/12/21 03:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
It is all about the total energy transferred to the atmosphere and how fast. Just like your car, you can stop it basically instantly from 100 mph by hitting a solid mountain cliff and it will cause great destruction to the car or you can disapate that same energy with the little bitty brake pads against the rotors more slowly and nothing gets harmed except some very tiny amount of pad and rotor wear and some heat released into the atmosphere, the same amount of energy is dissipated either way. If the rock hits the earth directly at 20 miles per second it will make a much larger explosion than the same size mass traveling 1/2 the speed and gently easing into the atmosphere at an angle. The way stuff is just flying around in the galaxy something very small could hit the earth and cause major destruction. They say the earth is flying around at thousands of miles per hour relative to the sun, something very small traveling equally fast in the opposite direction could hit with some serious energy and would be much harder to detect ahead of time than a large object traveling relatively slow with the same amount of energy.
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: HotRodDave] #2898495
03/12/21 04:25 PM
03/12/21 04:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Its also about the time of day the meteor arrives, in that a daylight explosion is likely noticed visually by very few.
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: Hugh Jorgan] #2898568
03/12/21 08:34 PM
03/12/21 08:34 PM
SattyNoCar Offline
SattyNoCar  Offline
Fixed.
Thank you. I stand corrected.
John
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: SattyNoCar] #2898576
03/12/21 09:17 PM
03/12/21 09:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I can't wait for the conspiracy theories to start !!!
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: Stanton] #2898603
03/12/21 10:34 PM
03/12/21 10:34 PM
Putin sent a drone to take out Joe, Reagans Star Wars system took the drone out whistling grin stirthepot
Ask and you will receive grin
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: Cab_Burge] #2898618
03/12/21 11:34 PM
03/12/21 11:34 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The Yellowstone Caldera will get us first.......
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: slantzilla] #2898759
03/13/21 01:50 PM
03/13/21 01:50 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Wait till all the oil is sucked out of the earth and then see what happens!
Re: NASA reveals what exploded over Vermont scary to say the lea [Re: A12] #2898768
03/13/21 02:12 PM
03/13/21 02:12 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Online content
moparmike1  Online Content
