Bad Vibration at Idle #2897744
03/10/21 02:31 PM
03/10/21 02:31 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
69 Charger 440 4bbl 727 trans. Not just an idle out of adjustment, but almost a rotational vibration. Damper looks good. ??
Grandma always said I had "hands of gold"!
Re: Bad Vibration at Idle [Re: CHRGR69] #2897751
03/10/21 02:55 PM
03/10/21 02:55 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Does it just do this while idling?
I bought a '72 Charger in AZ. back in the 80's with a 400 2-bbl that had a vibration at all RPM's. I sold the car to a customer before we ever got it figured out, but several guys were saying they thought it was the flex plate.
Re: Bad Vibration at Idle [Re: Sunroofcuda] #2897754
03/10/21 03:00 PM
03/10/21 03:00 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
That's what I was thinking but wanted someone else to say it. mad
Re: Bad Vibration at Idle [Re: CHRGR69] #2897760
03/10/21 03:08 PM
03/10/21 03:08 PM
an8sec70cuda Offline
Is this something that just recently started? Or is this a fresh build?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bad Vibration at Idle [Re: an8sec70cuda] #2897772
03/10/21 03:30 PM
03/10/21 03:30 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Just started
Re: Bad Vibration at Idle [Re: CHRGR69] #2897780
03/10/21 03:37 PM
03/10/21 03:37 PM
If it has good oil pressure and isn't making any knocking sounds, then pop the inspection cover off of the bellhousing and bump the engine over so you can look at the flexplate. It may have cracked.
I'd also verify that the balancer hasn't slipped the outer ring.
CHIP
Re: Bad Vibration at Idle [Re: an8sec70cuda] #2897866
03/10/21 07:30 PM
03/10/21 07:30 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
What is good oil pressure??
Re: Bad Vibration at Idle [Re: an8sec70cuda] #2897934
03/10/21 09:16 PM
03/10/21 09:16 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
On the balancer. You can run it up to TDC on #1 and see where the mark is. beer
Re: Bad Vibration at Idle [Re: TJP] #2897935
03/10/21 09:24 PM
03/10/21 09:24 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
iagree
thumbs
Re: Bad Vibration at Idle [Re: CHRGR69] #2898055
03/11/21 09:24 AM
03/11/21 09:24 AM
Depends on what oil pump is on it. If it has a stock pump, then probably 15 psi or so at hot idle and 40+ at speed.
A high volume pump will be at least 20 psi hot idle and 60+ at speed. Of course this can vary if someone has messed w/ the relief spring and/or bearing clearances.
Checking your timing is another way to easily see if they balancer has slipped. If the timing light is telling you the timing is different now than where you previously set it...it's time to get #1 at true TDC and verify the timing mark.
CHIP
Re: Bad Vibration at Idle [Re: an8sec70cuda] #2898065
03/11/21 09:50 AM
03/11/21 09:50 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Unless the poster has a newer cast crank external balanced engine a slipped internal balanced engines balancer will not cause a vibration.
Re: Bad Vibration at Idle [Re: NITROUSN] #2898073
03/11/21 10:04 AM
03/11/21 10:04 AM
up Yes, unless it's slipped BAD and is about to come apart/fall off. I mean like the outer ring is wobbling...but he did say it looks OK though didn't he? So yeah, the damper shouldn't be the issue if it's neutral balance.
Unless there's an issue w/ the flexplate or torque converter, it's gonna be time to tear into the motor.
CHIP
Re: Bad Vibration at Idle [Re: an8sec70cuda] #2898126
03/11/21 11:46 AM
03/11/21 11:46 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Simple firing order error?
Is there a miss, have you looked under the valve covers.... lifter popped out? Miss adjusted valves/preload?
STOP POTATO HATE!
Re: Bad Vibration at Idle [Re: Mr PotatoHead] #2898404
03/12/21 12:06 PM
03/12/21 12:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
How old is the gas? I'd drain the tank and put fresh gas in it before tearing into anything.
I put STA-BIL in my tank over the winter one year. When I took the car out of storage the engine had a noticeable vibration to it. Surprisingly, a fresh tank of gas fixed it.
Re: Bad Vibration at Idle [Re: an8sec70cuda] #2898454
03/12/21 02:03 PM
03/12/21 02:03 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
The damper looks fine and the timing is rock solid where ever I set it. I'm hoping the bolts that tie the plate to the torque converter are lose. Easy fix. Other wise mad
