Bad Vibration at Idle
#2897744
03/10/21 02:31 PM
03/10/21 02:31 PM
Posts: 1,534 Florida
CHRGR69
69 Charger 440 4bbl 727 trans. Not just an idle out of adjustment, but almost a rotational vibration. Damper looks good. ??
Grandma always said I had "hands of gold"!
Re: Bad Vibration at Idle
[Re: CHRGR69]
#2897751
03/10/21 02:55 PM
03/10/21 02:55 PM
Posts: 8,403 Highland, MI.
Sunroofcuda
Highland, MI.
Does it just do this while idling?
I bought a '72 Charger in AZ. back in the 80's with a 400 2-bbl that had a vibration at all RPM's. I sold the car to a customer before we ever got it figured out, but several guys were saying they thought it was the flex plate.
[Re: CHRGR69]
#2897760
03/10/21 03:08 PM
03/10/21 03:08 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Is this something that just recently started? Or is this a fresh build?
[Re: CHRGR69]
#2897780
03/10/21 03:37 PM
03/10/21 03:37 PM
an8sec70cuda
If it has good oil pressure and isn't making any knocking sounds, then pop the inspection cover off of the bellhousing and bump the engine over so you can look at the flexplate. It may have cracked. I'd also verify that the balancer hasn't slipped the outer ring.
[Re: an8sec70cuda]
#2897866
03/10/21 07:30 PM
03/10/21 07:30 PM
CHRGR69
What is good oil pressure??
[Re: CHRGR69]
#2898055
03/11/21 09:24 AM
03/11/21 09:24 AM
an8sec70cuda
What is good oil pressure?? Depends on what oil pump is on it. If it has a stock pump, then probably 15 psi or so at hot idle and 40+ at speed. A high volume pump will be at least 20 psi hot idle and 60+ at speed. Of course this can vary if someone has messed w/ the relief spring and/or bearing clearances. Checking your timing is another way to easily see if they balancer has slipped. If the timing light is telling you the timing is different now than where you previously set it...it's time to get #1 at true TDC and verify the timing mark.
[Re: NITROUSN]
#2898073
03/11/21 10:04 AM
03/11/21 10:04 AM
an8sec70cuda
Unless the poster has a newer cast crank external balanced engine a slipped internal balanced engines balancer will not cause a vibration. Yes, unless it's slipped BAD and is about to come apart/fall off. I mean like the outer ring is wobbling...but he did say it looks OK though didn't he? So yeah, the damper shouldn't be the issue if it's neutral balance. Unless there's an issue w/ the flexplate or torque converter, it's gonna be time to tear into the motor.
[Re: an8sec70cuda]
#2898126
03/11/21 11:46 AM
03/11/21 11:46 AM
Posts: 9,556 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Simple firing order error?
Is there a miss, have you looked under the valve covers.... lifter popped out? Miss adjusted valves/preload?
STOP POTATO HATE!
