Re: New carbs, linkage and lines, everything fits
[Re: an8sec70cuda]
#2897336
03/09/21 11:08 AM
03/09/21 11:08 AM
Posts: 1,169 MI
68shifter
MI
Looks great.
I’ve got a brand new set from Dale Cubic. If your ever at Martin it’d be an interesting comparison if you want to try them at some point.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: dvw]
#2897341
03/09/21 11:44 AM
03/09/21 11:44 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Looks great I am sure you will find your elusive 8 now.
[Re: 66coronet]
#2897683
03/10/21 11:37 AM
03/10/21 11:37 AM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
Are those Main bodies cast or billet? It is hard to tell from the pictures. I am bringing it up now so you dont end up in a pissing contest later. If they are BLP BX4 main bodies they're billet.
[Re: justinp61]
#2897716
03/10/21 12:55 PM
03/10/21 12:55 PM
Posts: 9,871 MI, usa
dvw
MI, usa
I think they are billet, why? What pissing contest? Doug
[Re: dvw]
#2897721
03/10/21 01:03 PM
03/10/21 01:03 PM
Posts: 1,443 central ohio
nss guy
central ohio
NMCA rules
CARBURETOR (NSS CLASSES): All entries in the eliminator must be carbureted as outlined below. Positioning of carburetors from factory mounting not a tech item (carburetors may be positioned facing forwards, backwards, or side mounted). Choke horn, choke plate, choke shaft, choke linkage, and choke mechanism may be removed. Carburetors are restricted to the following manufactures: Holley, Edelbrock, Carter, Rochester, Demon, Quick Fuel Technologies. Vehicles in this class permitted the use of carburetors listed for NSS, or Holley, Quick Fuel or Holley based carburetor 4150 style with a maximum 1.750 throttle blade. (NO Dominators). Carburetor must have commercially available cast main body. Billet Base Plate and metering blocks are permitted. All NSS combinations are permitted duel four carburetor setup. FUEL
[Re: 66coronet]
#2897808
03/10/21 04:31 PM
03/10/21 04:31 PM
Posts: 681 COLUMBUS, OH
Whompin_Wedge
COLUMBUS, OH
I was just going to wait until I had Doug in the finals to tell him they were illegal lol....
Honestly though... I think it is a silly rule. Don't see the advantage and most people wouldn't even be able to tell.
Thanks, Casey FJ
[Re: Whompin_Wedge]
#2897831
03/10/21 05:49 PM
03/10/21 05:49 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
So does the manufacturer also come into play here? Must be produced by one listed?
[Re: dvw]
#2898374
03/12/21 10:59 AM
03/12/21 10:59 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
VERY well done, looks nice, I like that the shafts are splined , on my 8 stack linkage they are not & they have slipped once, so I had to loctite them.
[Re: CSK]
#2898431
03/12/21 01:06 PM
03/12/21 01:06 PM
dvw
MI, usa
There is a pop off valve between the carbs. It popped once do to improper starting procedure. Never in 7 years since. There are no modifications to the intake. Power wise the Eddys with the crossram seemed very close. The closest motor to mine that I can think of was David Ross Charger. 572 from Best Engines with similar cam and compression. Dominator, 14x32 with a brake at I believe 3000lbs? 8.8x. Mine has been 9.00@3350 Doug
[Re: CSK]
#2898435
03/12/21 01:17 PM
03/12/21 01:17 PM
Posts: 4,091 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Looks good Doug!...you have any help? LOL I think the rules need revisiting. That rule may be written to maintain a 'nostalgic' appearance? There is no advantage using that body against the others available that are 'legal' when index racing. Based solely on 'nostalgic' appearance, your car fits that standard better than MOST that I have seen INCLUDING the appearance of the engine. Where would you draw the lines in that 'argument'? ...vacuum pumps, electric water pumps and fans aren't nostalgic but they are legal. Walk up to your car, and IT LOOKS NOSTALGIC! Pull the hood off, and IT LOOKS NOSTALGIC! Open your door, and IT LOOKS NOSTALGIC! Now if it had a sheet manifold, tin seats and Alumistars...not so much IMO. But those are legal?
