MPG on Pentastar 3.6L?
#2897084
03/08/21 12:19 PM
03/08/21 12:19 PM
Posts: 8,414 Highland, MI.
Sunroofcuda
Highland, MI.
Looking for answers/ideas here. This is a short account of 3 late model 300's I've owned - all with the 3.6L Pentastar motor.
* First one I owned was a 2012 RWD. It would get 25 MPG around town, & over 31 on the highway. * Second one was a 2014 AWD. It got around 24 around town, & 27 on the highway. * Current one is a 2016 RWD. It gets around 24 around town, but only 25 MPG on the highway - I just checked it last week.
Something does not seem right to me. Any ideas? I knew the AWD would get worse mileage & it did, but going back to just a RWD I thought I'd get all the mileage back like I got with my 2012. Not even close.
Re: MPG on Pentastar 3.6L?
[Re: Sunroofcuda]
#2897097
03/08/21 12:40 PM
03/08/21 12:40 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Something does not seem right to me. Any ideas? I knew the AWD would get worse mileage & it did, but going back to just a RWD I thought I'd get all the mileage back like I got with my 2012. Not even close. Typically my highway mileage wouldn't exceed 24 ~ 25 MPG (rated 31 MPG) between here and Las Cruces. Tough drive, high speed, usually a head or strong crosswind across west Texas, elevations from near 5,000 ft to ~ 600 ft. I made one round trip from here to Houston on one tank, registered a perfect 30 MPG driving easy on a calm day. Around town usually got high 18's to low 20 MPG, sometimes a little better. https://www.fuelly.com/car/chrysler/300/2013/bigironram/209359 It's funny, my '16 Hemi WILL get the rated 25 MPG between here and Las Cruces. The wife's Hemi Durango will also get real close to its rated 23 MPG on the same drive. https://www.fuelly.com/car/chrysler/300/2016/bigironram/788753
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Pacnorthcuda]
#2897135
03/08/21 03:02 PM
03/08/21 03:02 PM
Sunroofcuda
Highland, MI.
How do the weights compare? They should be almost identical.
[Re: 440_Offroader]
#2897372
03/09/21 01:27 PM
03/09/21 01:27 PM
Posts: 6,021 Salem
Grizzly
Moparts Proctologist
Salem
My 2014 Charger gets around 19mpg city/ 30mpg hi-way with the 8 spd trans. My bad city milage is due to a horrific amount of red lights on my short commute. Since your city mpg is good, I'm wondering if your trans is hitting high gear on the hi-way? Possibly torque converter not locking up? What's your rpm when cruising at 60mph? Just tossing out some ideas... That is definitely a thing on my 545rfe. It won't lock up until I get it past 70mph, then back it down to 60mph and the mileage jumps way up compared to unlocked. Having to do that little stunt almost cost me a ticket in a 55mph zone. Believe it or not he let me off when I explained Chryslers "programming". I took my truck back to the Dealer to see if they can do anything about it: nope. Have driven a few new vehicles that also don't lock up until you wind 'em past 65-70mph. ![mad mad](/ubbthreads/images/graemlins/custom/mad.gif) Appreciate the programming in my '01 that locks up at 52mph every time. Makes a big difference in my fuel mileage ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Mo' Farts
Moderated by "tbagger".
[Re: 440_Offroader]
#2897382
03/09/21 02:00 PM
03/09/21 02:00 PM
Sunroofcuda
Highland, MI.
The trans in this 300 has always been a little questionable to me - now you have me thinking. One thing it has ALWAYS done, is when coming to a stop, it BANGS pretty hard into the first gear - it's abrupt & harsh every time. I've always wanted to get this checked. None of my other two 300's have ever done this.
[Re: maximus]
#2897404
03/09/21 03:24 PM
03/09/21 03:24 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Winter fuel in Michigan has a different blend. Recheck your mileage in May. My 2013 Journey gets 24-25 highway during the winter and 28-29 during the summer when they change fuel mix. It has been this way for many years. My '17 is the same.
Rich H.
Esse Quam Videri
[Re: Sunroofcuda]
#2897931
03/10/21 09:08 PM
03/10/21 09:08 PM
Posts: 257 Alberta
440_Offroader
Alberta
The trans in this 300 has always been a little questionable to me - now you have me thinking. One thing it has ALWAYS done, is when coming to a stop, it BANGS pretty hard into the first gear - it's abrupt & harsh every time. I've always wanted to get this checked. None of my other two 300's have ever done this. My Charger does this as well on the odd occasion. Mine seems to happen, when doing a hard stop from some speed. I think it's only done it a few times in 2 years, so I haven't worried to much about it. I chauked it up to be too many gears, downshifting all at once.
