2011 Ram 1500 4X4 rear axle help
#2896631
03/06/21 11:06 PM
03/06/21 11:06 PM
Posts: 1,269 Way out in the sticks of Weste...
DusterDog
Can anyone tell me what all would be involved to put a 2013 Ram 1500 4X4 rear axle into a 2011 1500?? I'm looking at buying a 2011 that was hit in the right rear, bent some sheet metal, & bumper, broke the tail light, & broke the axle off at the end of the housing. The housing, & the lower control arm is bent as well. When I look at some of the local wrecking/salvage yards it seems that the 2011 model year is all by it's self as far as the axle.
I can get a complete (housing, control arms, & maybe the brake calipers) 9.25 from a local yard for a really good price.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: 2011 Ram 1500 4X4 rear axle help
[Re: GarageDodge]
#2896707
03/07/21 10:46 AM
03/07/21 10:46 AM
DusterDog
I'm going to take another good look at it this week. It appears that it was an angled hit, body lines/gaps looked good at first. I couldn't see any bends, or kinks on the frame. One of my co-workers says that Mopar changed the control arm design over the years, maybe made them heavier duty?? I'm thinking that if they made the control arms/bushings bigger, I "should" be able to drill the mounting brackets???
[Re: DusterDog]
#2896850
03/07/21 07:33 PM
03/07/21 07:33 PM
Guitar Jones
I'm going to take another good look at it this week. It appears that it was an angled hit, body lines/gaps looked good at first. I couldn't see any bends, or kinks on the frame. One of my co-workers says that Mopar changed the control arm design over the years, maybe made them heavier duty?? I'm thinking that if they made the control arms/bushings bigger, I "should" be able to drill the mounting brackets??? Unless they are wider. I don't know, just something to consider.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2896861
03/07/21 08:10 PM
03/07/21 08:10 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
09-12 use the same control arm.
