Re: cam choice for 440 with 1960's long ram manifolds? [Re: Sniper] #2895990
03/05/21 11:17 AM
03/05/21 11:17 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by Sniper
Who spins it over 5000 rpm on the street??
So you never had a car in HS then?
Re: cam choice for 440 with 1960's long ram manifolds? [Re: jcc] #2896006
03/05/21 11:48 AM
03/05/21 11:48 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Bought a 3" stroke car with 2x4's when I was 19 and out of HS. 8,000 RPM was the name of that tune. 4.56 gears helped too. whistling
Re: cam choice for 440 with 1960's long ram manifolds? [Re: John Brown] #2896064
03/05/21 01:59 PM
03/05/21 01:59 PM
moparx Offline
moparx  Offline
just zing it to the highest number on the tach ! if it wasn't meant to be, the tach manufacturer wouldn't have put it there ! biggrin
beer
Re: cam choice for 440 with 1960's long ram manifolds? [Re: jcc] #2896115
03/05/21 04:04 PM
03/05/21 04:04 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, I did, but I didn't drive like an idiot.
For that I had my motorcycle.
Re: cam choice for 440 with 1960's long ram manifolds? [Re: Sniper] #2896120
03/05/21 04:12 PM
03/05/21 04:12 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Hey, 5,000 rpm with low enough gears, just gets one to the legal speed quicker, being an idiot is optional, besides, toying with idiocy is how society sorts out the youngsters, I only referred to HS, because those 16 in Jr high, already have their own issues.
You did wear a helmet right? work
Re: cam choice for 440 with 1960's long ram manifolds? [Re: CSK] #2896616
03/06/21 10:05 PM
03/06/21 10:05 PM
Canada
demon Offline OP
demon  Offline OP
Canada
Originally Posted by csk
you need a cam in the 220ish@.050 & a wide LSA, 112 to 114 , the wide LSA keeps the exhaust pulse from affecting the ram pulse that the LONG runner creates , I would lean more to the 114 LSA, I would also cut a 30dg back cut on the intake valves ONLY, not the exhaust valves , I would also install the intake lobe @ 106 to 108
Good info. Thank you.
I am using the 1960 long ram intakes, which have full length divided runners, which apparently were designed for 2800 rpm.
Since this is a street only car, and where I live its a 60 mph speed limit and no freeways for 200 miles, it will be a daily driver in town, with occasional highway driving. I'm leaning towards 3.23 gears, with 28 inch tall tires.
As mentioned, I am looking for max low end torque, and preferably high vacuum for good mileage too. 4 speed manual transmission for the fun factor
Re: cam choice for 440 with 1960's long ram manifolds? [Re: demon] #2896618
03/06/21 10:16 PM
03/06/21 10:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I ran a 64 300 with 3.23 gears and 28" tires, N50-15's, that ran pretty decent but 4.10's really woke it up. But this was a single 4bbl 413, Street Hemi grind cam and a stick. Not a 440 with long horn cross rams, which will likely make a lot more torque if cammed right.
Re: cam choice for 440 with 1960's long ram manifolds? [Re: Sniper] #2898511
03/12/21 05:12 PM
03/12/21 05:12 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
Check out this thread on the Forwardlook forum: Dyno'd My 1960 413 Long Ram Engine This Week!
He did something close to what you are looking to do. His combo was 413 bored to 426, "sort" rams, cleaned up stock heads, and a hydraulic roller. He ended up with 516TQ at 3,600rpm 405HP at 5,000rpm. I would think the long rams would bring the peaks down a little lower in the rev range, but stealth heads should be better flowing and bump the numbers back up.
1958 Plymouth Suburban
Re: cam choice for 440 with 1960's long ram manifolds? [Re: BlueGhost] #2898577
03/12/21 09:20 PM
03/12/21 09:20 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My take, stock 413 LR motor I believe was OEM at 475lb/ft? A .560 lift cam on nearly stock heads with those long rams, seems way overkill, I would have liked to see less but faster lift, with a hyd roller, that is rpm limited,.more duration, wider, and up the CR, especially with Alum heads, and with EFI/timing w/knock sensors. it would allow OP to get dialed in.
My expectations would be a bit north of 516 on 110 gas.
