Re: Blinker light goes on when lights go on
[Re: kidmopar]
#2895804
03/04/21 07:48 PM
03/04/21 07:48 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
No. It sounds like either a bad ground or feedback one of the bulbs on that side. Go to either the front or rear and remove the bulbs. If the problem goes away that is the problem area. If it does the same go to the other end and try the same with the bulbs.
[Re: NITROUSN]
#2895813
03/04/21 08:10 PM
03/04/21 08:10 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
No. It sounds like either a bad ground or feedback one of the bulbs on that side. Go to either the front or rear and remove the bulbs. If the problem goes away that is the problem area. If it does the same go to the other end and try the same with the bulbs. Actually you might be on to something. My left front side marker pig tail is bad.
[Re: 70sixpkrt]
#2895834
03/04/21 09:08 PM
03/04/21 09:08 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Yep, chances are it's a ground issue on a park, tail or side marker light.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: topside]
#2896564
03/06/21 07:39 PM
03/06/21 07:39 PM
Posts: 4,923 new berlin wisconsin
Mr T2U
i had the same problem when i first built my 72 Roadrunner. it was a bad ground with the front turn signal housing.
perception is 90% of reality
[Re: Mr T2U]
#2896822
03/07/21 04:59 PM
03/07/21 04:59 PM
70sixpkrt
i had the same problem when i first built my 72 Roadrunner. it was a bad ground with the front turn signal housing. Bingo. That was the problem. Thank you
[Re: gtx6970]
#2898393
03/12/21 11:54 AM
03/12/21 11:54 AM
70sixpkrt
Mine does same thing,,, BUT only At times.
Right lamp in the dash is on but dim. head lights or just park lights on. makes no difference if I flip the turn signal to either side. No changes.
left turn signal works fine. when flip to right side the front and rear lights work as normal. But the right turn signal lamp in the dash stays illuminated . It does not blink when flipped to right side, yet the outside light flashes normal
Ive changed all 4 bulbs both front and rear both sides of the car, Twice. with no change .
issue on mine is the issue comes and goes I would loosen all the blinker and side marker housings and then retighten them. My problem was a loose front blinker housing not getting a good ground.
[Re: 70sixpkrt]
#2898503
03/12/21 05:01 PM
03/12/21 05:01 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
issue on mine is the issue comes and goes I would loosen all the blinker and side marker housings and then retighten them. My problem was a loose front blinker housing not getting a good ground. Becoming handy with a multimeter will be your friend and allow you to pinpoint what works or doesn’t, without disassembly
[Re: 70sixpkrt]
#2898557
03/12/21 08:00 PM
03/12/21 08:00 PM
Posts: 21,451 It's a dry heat
gtx6970
It's a dry heat
issue on mine is the issue comes and goes I would loosen all the blinker and side marker housings and then retighten them. My problem was a loose front blinker housing not getting a good ground. Did that. as well as loosened and retighten tail light housing AND both quarter ext hsgs . Loosened and tightened both front park lamp assy and even the top of the grille to body screws. using alligator clips attached separate grounds to each tail light socket to body Loosened and tightened the screws that attach the instrument cluster assy to dash frame retightend dash frame to A pillar bolts All = no change like I said, it comes and goes. Drove it in to work this morning and all worked perfect
