360 in a 1969 D100 what motor mount brackets to use? #2895563
03/04/21 11:23 AM
03/04/21 11:23 AM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
have a local guy wanting to put a 360 in a 1969 d100 , what motor mount brackets does he use?
Re: 360 in a 1969 D100 what motor mount brackets to use? [Re: Joesixpack] #2895567
03/04/21 11:33 AM
03/04/21 11:33 AM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
360 truck brackets 72-93 should work
Re: 360 in a 1969 D100 what motor mount brackets to use? [Re: Joesixpack] #2895568
03/04/21 11:33 AM
03/04/21 11:33 AM
IMGTX Offline
IMGTX  Offline
He will need the 340/360 brackets. The 318 brackets are different on one side.
I am not totally familiar with the D100 K Frame so if it was a /6 the K-Frame may need to be swapped or adapter mounts installed but I am not sure they are still being made.
Re: 360 in a 1969 D100 what motor mount brackets to use? [Re: IMGTX] #2895643
03/04/21 01:43 PM
03/04/21 01:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
318 ones will work, the difference is that the 318 bracket is a bit wider, about 1/2", on one side compared to the 340/360 brackets. some washers, a spacer, heck a 1/2" nut will fix that. BTDT.
