Page 2 of 4 1 2 3 4
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: 11secdart] #2894392
03/01/21 02:06 PM
03/01/21 02:06 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Originally Posted by 11secdart
I have a question I didn't notice when ordering: my 08 has a button on the shift lever for tow mode / OD off for towing . Does the new 8 speed with a shifter knob on the dash have the same capability?
Yes, the button is on the dash.
I've had 2 1500 5.7 trucks. I just tow and open trailer, but I have never needed to use TOW mode.
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: slantzilla] #2894394
03/01/21 02:11 PM
03/01/21 02:11 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Thanks Slantzilla! đź‘Ť
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: 440Jim] #2894429
03/01/21 03:38 PM
03/01/21 03:38 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Originally Posted by 440Jim
I have a 2015 RAM 1500 5.7 hemi with the 8-speed auto and 3.21 gears.
It tows the load great. That 8-speed makes all the difference. It has a very low 1st gear, and so many choices in "overdrive" gears there is one for every load.
When empty (no trailer), it goes 70 mph around 1600 rpm and gets great gas mileage. When towing my 24ft enclosed trailer loaded to 8,000 lbs it works great.
On the highway it stays in 6th gear so there is enough RPM (~2,200) to have the right power.
I have towed 9,500 lbs a few times and in the flat east it does just fine.
So, based on that; get the 8-speed with 3.73 gears and you will be happy with both towing and driving without a trailer.
Now if you must tow 13,000 lbs, or mountainous areas; that might be another story.
I do find it odd you want to get rid of your diesel; unless you don't plan to tow with the pickup truck much anymore.
Is this even a legal setup? I question people who pull boxes with full size 1500s let alone a short bed 2wd. Not about getting it moving its about getting it stopped. To each his own but if I see you going down the highway I'm pulling over and letting you pass, no way I'd want to be near that.
Buddy of mine has a 2020 with a 6.4 and says it has plenty of grunt. Id think 4:10s aren't needed with the new transmissions. However, I'd keep the 06 above all.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: A39Coronet] #2894460
03/01/21 04:14 PM
03/01/21 04:14 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Yes ... only mine is a small 20 ft trailer with a 3,000 lb car no stopping problem especially with the brake controller set properly . A friend has a similar truck only a GMC with a 24 ft trailer and a 4,000 lb car with no problems.
. I towed my trailer with an 00 Durango , a 92 D 150 reg cab/ short bed 2WD and my 08 H.Q.C 1500 and never had a problem stopping . I considered a 2500 6.4 8 ft bed but couldn’t get over the looks plus empty ride isn’t great and a quad or crew cab is just too big and expensive for me especially since I need 4WD . I do see your point though. I just looked up the specs on my trailer and new truck , my trailer empty is 3245 with my 3,000 lb. Dart that's 6245 even with my scooter, generator, tools etc it will below the 9,000 lb advertised towing capacity of the truck.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Dartsport540] #2894464
03/01/21 04:19 PM
03/01/21 04:19 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Originally Posted by Dartsport540
My 2006 and trailer weighs around 17,800. Gets around 8 to 10 while towing. Usually get around 14 to 16.5 empty. Got 19 a few times , when I was driving it, trying to get good mileage. Pulls and stops great. I just think I should get something New, while I can still get good money for it. Just listed it on Marketplace earlier today.
Quite a difference on this Bullschitter forum full of guys like Guitar Jones claiming their Cummins get 28 mpg empty and 18 to 20 loaded. wink Your numbers are bang-on what a Common Rail Dodge gets, thank-you for the honest numbers! up
My 2008 Hurricane 33' class A motorhome. With a Ford F43 Chassis, V10. 17,800 miles. Pulls great stops good. Fuel mileage is 5.4 to 6.1 towing trailer. Weighs 26,000 lbs. with trailer. Gets 6.2 to 7.1 without trailer.
If it's legal in your state, cut your catalytic convertor off. I took mine out and the mileage is a bit better than yours, and no check engine light.
I would like to order 2021 Ram 2500. I was at dealer on saturday and priced 1 out with what I want. I think I will stay with 3.73 gears. Local track is only 12 miles from home. Any farther , and I will take motorhome.
Good decision. twocents
By the way, that Hurricane is a nice machine: I looked at one before I got the Gulf Stream Link to RV photo.
Mo' Farts
Moderated by "tbagger".
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: A39Coronet] #2894465
03/01/21 04:23 PM
03/01/21 04:23 PM
NC
440Jim Offline
440Jim  Offline
NC
My actual truck, with the factory equipment, empty weight, etc. is rated 8,700 lbs trailer. The published charts are for an average sales optioned truck (8,630 in 2015). Most 1500's have so much dead weight (quad/crew cab, 4x4, "big horn equip") etc. they can't pull as much trailer. Some only 7,000 lbs since they hit the truck "payload" weight limit before the trailer limit.
My empty truck (see shipping weight) is very light. Leaves more for payload, etc.
The optional equipment, driver+passengers, fuel, trailer tongue weight, hitch wt., etc have to be accounted for.
So my typical 7500-8000 lb trailer with only me and fuel is below all my truck's ratings. My cooler, etc are all in the trailer.
That 9,500 lb example is too heavy. IMO, it is really a handling issue; not a pulling or stopping issue. The brakes on a 2500 are not much better, but the chassis is better.
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: varunner] #2894521
03/01/21 06:22 PM
03/01/21 06:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted by varunner
Well my junk is the same truck as your junk,, except I have better ratio, 3.55. It pulls great, but fully loaded, it will drive right thru someone in a hard stop. I was asking to see how your braking works since you decided to get off topic cool
The key to stopping a trailer is having good brakes on it. I pull my Dart on a 18' gooseneck trailer with a 14 Ram Crew cab 4wd with 3.21 gears. The trailer has 5200# axles with brakes on both and have hauled my 7000# tractor and had no issues stopping. Just have to adjust the gain on the brake controller. Why anyone would buy a 24' or bigger enclosed trailer without 5200 or 6000# axles is beyond me.
A buddy of mine just bought a new 2500 with a 6.4 and 3.73 gears but hasn't towed with it yet. He's replacing a 98 CTD 2500.
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Dartsport540] #2894556
03/01/21 07:52 PM
03/01/21 07:52 PM
IL
Dart451 Offline
Dart451  Offline
IL
How much you asking for 06 got a friend looking for one
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: 11secdart] #2894562
03/01/21 08:16 PM
03/01/21 08:16 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
It has tow mode, I think the button is in the center area below the screen and heater/volume knobs, in the row of switches where the brake controller controls are. Ask me again in 10-12 weeks and I’ll let you know for sure!
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Mastershake340] #2894578
03/01/21 09:10 PM
03/01/21 09:10 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Thanks I was wondering where the brake controller was also.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: 11secdart] #2894605
03/01/21 10:30 PM
03/01/21 10:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The trailer brake setup will come up in the speedometer screen, and you can scroll through the menu to get to it.
My 2020 also extends the blind spot alarms for the added length of the trailer.
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: slantzilla] #2894611
03/01/21 10:56 PM
03/01/21 10:56 PM
IL
furious70 Offline
furious70  Offline
IL
we've got a 2019 2500 6.4 with the 6spd auto. It's a fine truck, rides a lot better than the 1996 cummins it replaced. The gas engine is fine.....but I do miss the torque!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Dart451] #2894659
03/02/21 07:06 AM
03/02/21 07:06 AM
Ringtown, Pa.
Dartsport540 Offline OP
Ringtown, Pa.
$32,000 with plow. $30,000 with out plow.
I am not sure if link will work. https://www.facebook.com/marketplace/item/830180060898212
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Dartsport540] #2894727
03/02/21 10:46 AM
03/02/21 10:46 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Eliminate Flippers: Take all the serious inquiries you have and set them all for viewing on the same day. Line 'em up and have a bidding war. twocents
Should get at least $35,000.00 for it being rust-free and low miles.
Mo' Farts
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Dartsport540] #2894737
03/02/21 11:05 AM
03/02/21 11:05 AM
IL
Dart451 Offline
Dart451  Offline
IL
Thanks I will pass it on to them.
Will be interesting to hear your thoughts on the 6.4 when you get it
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Dartsport540] #2894789
03/02/21 01:10 PM
03/02/21 01:10 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I have a 2019 with the 6.4 and 3.73 gears. I have been doing a bit of hauling for folks, and I really like the truck. I hauled a 2004 extended cab short bed 2wd from Michigan to PA last weekend, then took it to South Carolina to pick up another car. With the truck on my 1800 pound trailer, it used some gas on the hills in PA. But it never slowed down. I averaged 11.6 for the trip and in the hills the worst tank I got was 9.54 mpg. I love the truck, and for what I do, I don't think a diesel would be cost effective.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: OhioMopar] #2895117
03/03/21 09:00 AM
03/03/21 09:00 AM
NC
440Jim Offline
440Jim  Offline
NC
Do you have the 6-speed or 8-speed automatic transmission?
The transmission ratios are significantly different. And ofcourse the 8-speed has closer spacing for just the right RPM at MPH.
66RFE: 3.231, 1.837, 1.41, 1.00, 0.816, 0.625, ------, ----- Rev 4.44 (RAM 1500 65RFE 0.67 top gear)
8HP75: 4.710, 3.140, 2.10, 1.67, 1.290, 1.000, 0.84, 0.67 -Rev 3.06 (4WD)
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: 440Jim] #2895118
03/03/21 09:07 AM
03/03/21 09:07 AM
Crook County, ILL
Crook County, ILL
The 8 speed is standard with gas 2019- present.
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: Mastershake340] #2895121
03/03/21 09:12 AM
03/03/21 09:12 AM
NC
440Jim Offline
440Jim  Offline
NC
The 6-speed is optional.
Recall with 6-speed ... 2019-up 6-speed recall
Re: Anyone towing with a 2021 Ram 2500 Hemi 6.4?? [Re: 440Jim] #2895134
03/03/21 09:45 AM
03/03/21 09:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Interesting reading..... I’ve noted at work over the past 3 years the snowbird crowd has been going to the 6.4. In talking with customers it’s the usual.... mpg sucks, don’t get in hurry, but overall most are satisfied with their purchase. No def, no fuel filters every 15k, huge savings at purchase. I think technology/pricing is finally catching up to the diesel market. I’ve thought the 6.4 might be a viable option if I were to ever “upgrade” my pickup..... but more than likely we’ll try ride the ole 01 to the end. We’re currently 18700lb combined and I live at 500ft and have to climb 3500 to get out of town so the terrain is not friendly by any means. Funny how I’m seeing fewer and fewer 2nd gens at the track... I’m almost at that “antique” cool stage! laugh2
Page 2 of 4 1 2 3 4
