Rookie Mistake #2894987
03/02/21 09:04 PM
03/02/21 09:04 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
Had an oil pump gasket leaking on the 440 in my pickup. Went thru an act of Congress to get the pump out. Someone used 4x4 motor mount brackets that capture the pressure spring cap, so you can't just drop the oil pump. Anyway, I went with a brand new pump and like a dummy didn't pack the new pump with Vaseline like I usually do. This is my daily driver, so I was in a hurry to get it up and running. Never even put oil in the pump so it would prime. Therein lies my problem, can't get the pump to prime. I have a priming tool but , can't get it to suck up oil. Any suggestions,(other than get a clue) would be appreciated.
Re: Rookie Mistake [Re: elmor353] #2894996
03/02/21 09:17 PM
03/02/21 09:17 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
your turning it counter clockwise right?
Filled the filter ?
Re: Rookie Mistake [Re: Wirenut] #2894999
03/02/21 09:37 PM
03/02/21 09:37 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
Yes on both.
Re: Rookie Mistake [Re: elmor353] #2895026
03/02/21 10:16 PM
03/02/21 10:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Pull the filter and use a vacuum pump and try to draw oil into the pump. If not just pull it and prime it. Somebody slowly turning the pump may help when you apply the vacuum.
Re: Rookie Mistake [Re: elmor353] #2895087
03/03/21 03:25 AM
03/03/21 03:25 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
why did you change th pump?
is your pick up cloged ?
Re: Rookie Mistake [Re: elmor353] #2895096
03/03/21 05:51 AM
03/03/21 05:51 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Make sure the "O" ring is on the neck part of the pump that slides into the block.
That "O" ring is on the suction side, so if it does not seal, the pump will be sucking air.
Re: Rookie Mistake [Re: 451Mopar] #2895115
03/03/21 08:48 AM
03/03/21 08:48 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Spin it faster (get a faster drill, or set it on high speed)
Re: Rookie Mistake [Re: calrobb2000] #2895252
03/03/21 03:16 PM
03/03/21 03:16 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
The pickup isn't clogged. I had to remove the pump to replace a leaking gasket so I figured why not replace the pump with a new one since I had it apart. Typically I'm very meticulous when working on my vehicles but,I was in a hurry trying to get it up and running and back on the road as soon as possible and it came around and bit me in the a$$.
Re: Rookie Mistake [Re: elmor353] #2895263
03/03/21 03:42 PM
03/03/21 03:42 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have never packed a pump with anything. "Prime" ??? Never had to do that.
This is a problem for some people?
Re: Rookie Mistake [Re: Kern Dog] #2895273
03/03/21 04:15 PM
03/03/21 04:15 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
This happened to me on a 400 I rebuilt. What worked for me was removing the oil filter and priming it again. Eventually the oil gushed out the filter hole.
Re: Rookie Mistake [Re: 440newport] #2895368
03/03/21 07:49 PM
03/03/21 07:49 PM
Elmor, try loosening the oil filter enough to allow the air in the filter to be pushed out until it starts pumping oil in the pump, you will hear the drill motors start to slow down when it starts sucking the oil up into the pump scope
Re: Rookie Mistake [Re: Cab_Burge] #2895771
03/04/21 06:26 PM
03/04/21 06:26 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I've done dozens of big blocks and never had this issue before. Most of them never even had oil put in the pump. I know that the pickup tube isn't plugged, because I had 70lbs of pressure on the other pump.
Re: Rookie Mistake [Re: elmor353] #2895869
03/04/21 10:42 PM
03/04/21 10:42 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Same here, only person I ever saw pack the pump with Vaseline was working on a buick.
I'd suspect the pressure relief piston is stuck, either take it out and polish it, or take the pump back for a refund.
