Launch video- thoughts on taming this a bit? #2894273
03/01/21 06:37 AM
03/01/21 06:37 AM
gregsdart Offline OP
Iron block 550, 10.5x33 Hoosiers. 6000 stall, launch at 4200. Torqueflite, 4.56 gears in back. Front ladderbar bolt in bottom hole 5 3/4 inch off the track. Afco big guns in back, rebuilt Afco dbl adj in front. 106 wb, in this vid there was 47% on the back tires. My new block will drop 112 lbs off the car. With engine setback that will remove about 15 lbs from the back and about 98 from the front. Car and driver will weigh 2900. I already have the battery up in front of the radiator so moving wieght forward is not possible. The wheelie bars are 66 inch long and i do plan to lower them an inch or two.
The hoosiers have no tubes and are on a 14 inch rim. I run 8.5 psi so far. 60 fts have been inconsistant and i am thinking a touch less launch rpm (3800?) and raise the ladderbars up to the third or top hole to slow wheelspeed at launch. Thoughts?
https://m.facebook.com/story.php?story_fbid=10225104160328116&id=1142132673
Re: Launch video- thoughts on taming this a bit? [Re: gregsdart] #2894347
03/01/21 12:18 PM
03/01/21 12:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
An aluminum block aint gonna help for sure. I think we have discussed this before but wheelspeed is your friend. Also running the launch RPM down will be a good bandaid, it will give the car a "run" at the converter, but may affect your ability to hit the tree some.
Re: Launch video- thoughts on taming this a bit? [Re: Al_Alguire] #2894396
03/01/21 02:17 PM
03/01/21 02:17 PM
Ringtown, Pa.
Dartsport540 Online boogie
Dartsport540  Online Boogie
Ringtown, Pa.
Best thing that I have done for mine, was a custom built set of front shocks from Santhuff.
I have a chassis car with ladder bars. I have a solid set of wheelie bars. Ladder bar is in lowest hole. I can go from 4" wheelie to a 4' wheelie by adjusting the extension on the front shocks. About 6 to 7 clicks on extension. Tighter keeps front end down, looser gives bigger wheelies. Too tight and it will spin. I only have 2-1/2" to 2-3/4" of front shock travel. I didn't believe that I could calm my wheelies down by front shock adjustment, when I talked to Santuff. But it worked for me. I also have 51-1/2 % weight on rear wheels, 48-1/2 % on front wheels.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Launch video- thoughts on taming this a bit? [Re: Al_Alguire] #2894489
03/01/21 05:08 PM
03/01/21 05:08 PM
Just the change in tires from the big 2078 Goodyears to 10.5s seemed to slow the reaction time at least .02. So my thought was to drop the launch rpm but hit the tire more with the ladderbars to gain consistancy. Since i race in a box class loss of vehicle reaction time at the hit isn't a big deal . Right now it looks to have too much pitch rotation? As i recall Al your Barracuda was in a similar situation?
Dartsport i had my front afcos rebuilt and asked the guy to tighten them up. Also not sure what you are running for ET, but in my case adding enough power to go from 9.50s to 8.90s was a huge change in my car.
Re: Launch video- thoughts on taming this a bit? [Re: gregsdart] #2894495
03/01/21 05:20 PM
03/01/21 05:20 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Are you heads up or a bracket guy?
Because if your a bracket guy, why hit the convertor at 4200? You can lower that down...It will affect where you hit the tree, but all that can be re-tuned with front tire pressure and other little tricks like the front shock extension clickers...etc. I typically leave off the brake at 2k-2.4k, but last year looking for ET, I turned it up to 4k and then the wheelies were big enough to bounce the front end. I turned it back down the next weekend. Mines programable, and I don't need any chips. You just need to lift them a little to transfer all the weight.
If you have to run the convertor so high, I would defiantly lower the damn wheelie bars...Why have them if you aren't going to use them. Make sure you have fresh gr8 hardware on them too! From there, I would program a custom timing curve and back some of the timing down...This is probably the easiest way to manage the power and be able to adapt to track conditions.
I am not nearly as fast as you guys, but I plan on sneaking into the 9.30/5.80 zone this year, so we will see. I do not run any wheelie bars....So keeping the front down is kinda part of the game.
Re: Launch video- thoughts on taming this a bit? [Re: Dragula] #2894528
03/01/21 06:47 PM
03/01/21 06:47 PM
I run brackets. The plan will be to drop rpm some. Trial and error.
Re: Launch video- thoughts on taming this a bit? [Re: gregsdart] #2894535
03/01/21 07:06 PM
03/01/21 07:06 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'm an idiot lol
Forgot most of what I knew 😆
Re: Launch video- thoughts on taming this a bit? [Re: gregsdart] #2894542
03/01/21 07:14 PM
03/01/21 07:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
First thoughts. The wheelie bars are way too high. The front has unnecessary travel. Lots of wasted motion. I'd address those issues first. Is the fuel cell up front? Have you run the front extension full tight? I would not raise the ladder bars. Why add hit that it doesn't need?
Doug
Re: Launch video- thoughts on taming this a bit? [Re: FastmOp] #2894552
03/01/21 07:24 PM
03/01/21 07:24 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
You've shortened the factory wheelbase by 5". The front end of that body style, less the inner fenderwells, is light and the weight transfer is easy with the factory wheelbase of 111". I easily pull the front wheels with my SB '65. Tighten the front shocks and go with a 4.10 gear. You could add 2 lbs to the rear tires and let the slip be your friend.
Re: Launch video- thoughts on taming this a bit? [Re: A/MP] #2894602
03/01/21 10:24 PM
03/01/21 10:24 PM
Dragula Offline
Dragula  Offline
And depending on what trans you run, you can mild up 1st gear, or if your running a 727, leave in 2nd...I don't have your issue yet...lol
Re: Launch video- thoughts on taming this a bit? [Re: gregsdart] #2894759
03/02/21 12:03 PM
03/02/21 12:03 PM
Nevada
merpar Offline
merpar  Offline
Nevada
In my humble opinion, If not out of your budget. Get rid of the ladder bars they are violent on the hit. And put in a 4-link. Second. why a 6000 stall? Seems excessive to me, you have a torque monster. I would guess 5000 to 5200 stall. And if you are launching at 4200 you are hitting your convertor harder and possibly making it stall even higher. Good luck to you I'm sure you will find your sweet spot.
Re: Launch video- thoughts on taming this a bit? [Re: merpar] #2894766
03/02/21 12:16 PM
03/02/21 12:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My small tire Barracuda was only happy with the front end up in the air. Ladder bar car with a fairly high crank centerline and way to high of a ride height. All those factors contributed to its propensity to do wheelies. We also ran a MUCH smaller tire at 29.5x10.5". It was basically a small tire SS car and never meant to have 1300hp. We can do the same in the Vette, mile high wheelies for 150' if we choose. It is a ladder bar car as well but its 95" wheelbase and 32" ladder bar contribute there. Wheelspeed takes care of that issue in the Vette for sure, shock adjustment, launch rpm as used to reach that goal. We leave at the lowest RPM the conditions will allow, sometimes as far down as 3800rpm WELL below converter stall for sure. It gives the car a "running" start at the converter. We have not run that car since September of 2019 and now have new shocks all around in an effort to get it to leave as flat as possible. I am sure we will look like idiots here in a couple weeks with all the new pieces on the car. Different trans ratio(we run a proflite), different pump configuration, more rear gear, new shocks, more power blah blah blah. FWIW we are also at 56/44 on weight bias in the car. It is perfectly consistent this way as well. My TS car sees plenty of wheelspeed as well and we have no issues with consistency there either.
Re: Launch video- thoughts on taming this a bit? [Re: Al_Alguire] #2894967
03/02/21 08:04 PM
03/02/21 08:04 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
I realize it is sacrilege but maybe a Powerglide????
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: Launch video- thoughts on taming this a bit? [Re: 451Guy] #2895102
03/03/21 07:13 AM
03/03/21 07:13 AM
PA
Harry's Taxi 2 Offline
PA
or pull a couple of plug wires off.....same philosophy.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Launch video- thoughts on taming this a bit? [Re: gregsdart] #2895129
03/03/21 09:34 AM
03/03/21 09:34 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
You did not mention your shocks, a good double adjustable shock on all four corners, should get you where you want to be. A travel limiter on the front end may be a cheap way to kill some of the wheelstand. Your issue is why I don't like ladder bar cars, if they work great, if you need to tune them a little, what do you do? A 4-link, quick adjustment to take out a little hook. On the other hand, it was a great launch, and looked straight and under control, I am sure the crowd likes to watch your car run.
Re: Launch video- thoughts on taming this a bit? [Re: jwb123] #2895181
03/03/21 12:34 PM
03/03/21 12:34 PM
I had the bars as high as they will go to see what would happen going from 15x15x33 to 10.5x15 x33 slicks. I understand the theory behind a low launch, but not all cars respond well to that. Mine seems to like at least a foot of daylight under the front tires on launch. Since my CG is too high and too far back that might be a big part of it. Then i opt for an aluminum block for this next season. Front end % will go from 53 to 51.5
That will drop the weight 112 lbs, about 95 off the front end. So that is why i have so much interest in what can be done to limit violent wheelstands, since i expect the loss of front end weight will hurt a lot. Fuel cell is up front, battery is in front of the radiator.
Thanks everybody for contributing. I plan to drop launch rpm and raise the front of the ladderbars to compensate, and control it with Big Gun Afcos . Front shocks are DA afcos rebuilt and revalved stiffer so i can lock up the front rise if needed. I am interested in more feed back so fire away!
