2014 RAM 1500 Full size spare? #2894369
03/01/21 01:04 PM
03/01/21 01:04 PM
Connecticut
Ron_M Offline OP
Ron_M  Offline OP
Connecticut
Greetings! I have a 2014 RAM 1500 Express with the 20x9 WR2 Aluminum chrome clad wheels fitted with the Goodyear P275/60R20 Wranglers. Spare is the 17 inch steelie with temporary rubber.
Does anyone have real world experience using a 20 inch steel rim with the same P275/60R20 Wrangler? It appears that part number 05290568AA is the OEM rim and could work. Research shows that this combination will be a tight fit on the under bed carrier but will work. Buying an extra WR2 isn't an option as a spare because of the price, plastic chrome clad, and that the living conditions will beat the devil out of the wheel. There also appear to be economy offshore rims, any thoughts on those? (Rockauto 69955 / 2470)
Thanks in advance!
Common sense is a flower that does not grow in everybody's garden
Re: 2014 RAM 1500 Full size spare? [Re: Ron_M] #2894547
03/01/21 07:21 PM
03/01/21 07:21 PM
5thAve Offline
5thAve  Offline
There shouldn't be any problem using that tire on a steel wheel.
I never even bothered to look to see what tire is on my spare now I'm wondering.
Re: 2014 RAM 1500 Full size spare? [Re: 5thAve] #2894563
03/01/21 08:21 PM
03/01/21 08:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 2105 2500 4x4 came with 18" Goodyear tires and had an 18" Firestone spare on a steel wheel! I asked the dealer about it and he said the Firestone tires were $10 cheaper, so the bean counters saved the company $10 times the number of 2500's sold...LOL
JB Rhinehart, Realist
A-Body's RULE!
Re: 2014 RAM 1500 Full size spare? [Re: Rhinodart] #2894590
03/01/21 09:59 PM
03/01/21 09:59 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
My 2015 2500 4x4 came with Goodyear duratrack's on all 4 corners including the spare. Spare was on a steel wheel instead of aluminum which is normal. If you have a different brand spare than someone did a switch and it was not the factory.
Re: 2014 RAM 1500 Full size spare? [Re: NITROUSN] #2894794
03/02/21 01:29 PM
03/02/21 01:29 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Back in by dealership days the spares were removed and stored inside. Once sold the spares were put back on the truck...not always the one that came with it. work If the cost was the true reason than it would have had Firestones all the way around $10 X 5...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 2014 RAM 1500 Full size spare? [Re: NITROUSN] #2895041
03/02/21 10:58 PM
03/02/21 10:58 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I bought the truck new from the dealership that sponsors my Mopar show. I looked at it the day after it was taken off the transport truck and bought it that day, so the spare tire was from the factory. The original tires were on steel wheels with chrome cladding and the spare was a steel wheel without cladding.
A-Body's RULE!
Re: 2014 RAM 1500 Full size spare? [Re: Rhinodart] #2895137
03/03/21 09:55 AM
03/03/21 09:55 AM
N
N
Then you should of demanded the right tire. Look at every other truck and they should not have it. Being a past dealership owner I do know whats right and what is wrong.
Re: 2014 RAM 1500 Full size spare? [Re: NITROUSN] #2895139
03/03/21 10:02 AM
03/03/21 10:02 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I only noticed it when I ran over a chunk of marble in the road and cut the right rear original tire at around 25K miles and had to change it. Not a big deal as I was close to needing new tires by then anyway. As you know the factory installed tires don't last long for some reason...
A-Body's RULE!
Re: 2014 RAM 1500 Full size spare? [Re: Rhinodart] #2895714
03/04/21 04:12 PM
03/04/21 04:12 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
That is because OEM tires are tuned for many attributes (noise, wet/dry/snow/mud traction, rolling resistance, etc), but there is no requirement for wear rate
Re: 2014 RAM 1500 Full size spare? [Re: 73MagDuster] #2895858
03/04/21 10:23 PM
03/04/21 10:23 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I only run old style Continental Conti-Tracs for the last 247k miles. On my 4th set now, so over so 65K miles on each sets so far, and I love the traction! Too bad they changed the tread pattern on the new ones, but there are plenty of the old style out there still... up
A-Body's RULE!
Re: 2014 RAM 1500 Full size spare? [Re: Rhinodart] #2895867
03/04/21 10:32 PM
03/04/21 10:32 PM
N
N
My dura tracs went 55,000 and had 10,000 left. I only changed them early because of hunting and our winters.
