1971 Hemi B-Body Master Cylinder - Any Difference?
#2894348
03/01/21 12:19 PM
03/01/21 12:19 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I'm aware that 1970 and down Hemi MCs were taller and higher capacity than 440s, 383s, etc. Even the 1970 Hemi Air Grabber cars had a hole cut into the air box for clearance, but I can't find anything on the 1971 Hemi cars. Did they also receive a special MC?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 1971 Hemi B-Body Master Cylinder - Any Difference?
[Re: RSI700VIPER]
#2894350
03/01/21 12:20 PM
03/01/21 12:20 PM
Posts: 3,075 Michigan
A727Tflite
Yes.
Look at RamMan for more info.
therammaninc.com
[Re: Mastershake340]
#2894376
03/01/21 01:20 PM
03/01/21 01:20 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Yes, 70-71 disc brake hemi cars had a unique master cylinder. Chrysler part number 2944476 with Bendix casting number 2229191 on the bottom. It looks like the ‘70 E body only disc brake part, except it’s 1-1/8” bore, different casting number and has a piston retaining bolt on the bottom of the casting. IIRC there's 2 versions of this casting, one with lines inboard (facing engine) the other with lines outboard, HEMI application is lines outboard
[Re: DAYCLONA]
#2894384
03/01/21 01:47 PM
03/01/21 01:47 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
No the B body 67-70 style with the taller thinner style casting is what you are thinking of. The outlets outboard version is casting 2225621 and is found on all disc 67 B bodies, 68-69 hemi B bodies, and 70 disc C bodies ( under several different Chrysler part numbers and perhaps some slight piston length differences, though they are all 1-1/8 bores). The same style except lines exiting toward engine is casting number 2226821 and was used on 68-70 B bodies disc except hemi, again several Chrysler part numbers with slight piston length variations. Hemi 70-71 disc is casting 2229191 and has a lower wider casting, although like the previously described B body disc masters has a “thermometer” style front of casting. The part numbers, casting numbers and photographs of the different styles is documented in the Pulitzer Prize winning 2005 article pumping points in Mopar Action, if you have a copy of it in your old magazine stash. http://www.moparts.org/Tech/MoparAction/Next/history/april2005.html
#2894417
03/01/21 03:05 PM
03/01/21 03:05 PM
RSI700VIPER
NW New Jersey
Thanks for all the posts. Master340 - I might actually have that article in my stash.
[Re: RSI700VIPER]
#2894454
03/01/21 04:09 PM
03/01/21 04:09 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
I'm going to guess we're talking about your 71 Runner? Survivor photos for reference.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
#2894503
03/01/21 05:46 PM
03/01/21 05:46 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
The blue car and red car have aftermarket replacement master cylinders installed, the green car has a correct 2229191. Easily distinguishable I would assume, because the 'thermometer' at the front of the masters has the divot on the blue and red car and the green car does not.
#2894527
03/01/21 06:46 PM
03/01/21 06:46 PM
Butterscotch71
Lost Title
Lost Title
this one is a little easier to see without the black paint
[Re: dragon slayer]
#2894625
03/01/21 11:30 PM
03/01/21 11:30 PM
RSI700VIPER
NW New Jersey
Dragon - Were the master cylinders, MC cap, booster and booster valve painted as one assembly (bolts, gaskets, etc.) or were they painted black separately and bolted together later?
[Re: moparx]
#2895002
03/02/21 09:41 PM
03/02/21 09:41 PM
RSI700VIPER
NW New Jersey
I would take a divot MC over what I have now.
