Re: engine tilts aft a lot how to fix
[Re: frank]
#2893831
02/27/21 06:12 PM
02/27/21 06:12 PM
Posts: 10,758 North Dakota
6PakBee
North Dakota
Is the ride height of the body where it should be? Specifically the front end.
[Re: TJP]
#2893910
02/27/21 10:24 PM
02/27/21 10:24 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Gabriel Hijackers will fix this LOL Good one ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) On a more serious note, I'm going to say the mounts are incorrect for you K frame / engine combo. We had a Charger in a while back with a Magnum force front Suspension and a hemi that was shoved so far to the right that the valve cover was dented and it was still hitting the shock tower at rest. No need for a torque strap on that one LOL. We wound up redoing the mounts to get the motor centered and level side to side. And yes it was a PITA I agree. Unless you have some corn bread concoction get the factory mounts and isolators and you will be fine. Having to fight to drop it in place tells me you have a concoction of incorrect parts.
[Re: earlymopar]
#2893974
02/28/21 09:15 AM
02/28/21 09:15 AM
6PakBee
North Dakota
I'm not sure what you would do. But I do know that all the specifications are with the tires installed and the car on the ground. Once you have the car on jackstands, who knows where you are.
[Re: NITROUSN]
#2894122
02/28/21 04:54 PM
02/28/21 04:54 PM
Posts: 2,138 tucson az
frank
tucson az
Measure from the center of the crank to the K-frame. 5 1/4 inches is what you want to see. Measure from the center of the crank to each frame rail. Subtract lower from the higher number and the difference should be 2 1/2 inches. The motor sits closer to the right frame rail by 1 1/4 inches. Measure and report back. With the car still on jacks (I will downjack and take all measurements again) the distance from center of crank, as measured from center of crank bolt, to K frame is 5 1/2 inches. Distance to passenger frame rail 14 1/2 and to drivers frame rail 17 inches
[Re: frank]
#2894129
02/28/21 05:10 PM
02/28/21 05:10 PM
Posts: 3,101 Michigan
A727Tflite
Last measurement should tell the story - measure from the top of the bellhousing to a given location on the firewall. Or using a straightedge - top of bell to the top of the inner apron tops.
Or top of extension housing to the cross member support horseshoe - the part weld in the car.
Maybe some one here can provide those measurements.
[Re: frank]
#2894133
02/28/21 05:16 PM
02/28/21 05:16 PM
NITROUSN
Measure from the center of the crank to the K-frame. 5 1/4 inches is what you want to see. Measure from the center of the crank to each frame rail. Subtract lower from the higher number and the difference should be 2 1/2 inches. The motor sits closer to the right frame rail by 1 1/4 inches. Measure and report back. With the car still on jacks (I will downjack and take all measurements again) the distance from center of crank, as measured from center of crank bolt, to K frame is 5 1/2 inches. Distance to passenger frame rail 14 1/2 and to drivers frame rail 17 inches On stands of on the floor those measurements will not change. If they do in will be minimal. Sounds like you are very close. As Transman mentioned a rear measurement would also help. Center of transmission output to floor would help. I do not have that number but maybe someone might.
[Re: A727Tflite]
#2894202
02/28/21 09:03 PM
02/28/21 09:03 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Maybe some one here can provide those measurements. I just put a 383 and 727 in my project 1970 Charger.
[Re: frank]
#2894231
02/28/21 10:49 PM
02/28/21 10:49 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
Measure from the center of the crank to the K-frame. 5 1/4 inches is what you want to see. Measure from the center of the crank to each frame rail. Subtract lower from the higher number and the difference should be 2 1/2 inches. The motor sits closer to the right frame rail by 1 1/4 inches. Measure and report back. With the car still on jacks (I will downjack and take all measurements again) the distance from center of crank, as measured from center of crank bolt, to K frame is 5 1/2 inches. Distance to passenger frame rail 14 1/2 and to drivers frame rail 17 inches Sounds like you don't have a problem...
