E-body frame splash shield removal #2893907
02/27/21 10:06 PM
02/27/21 10:06 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Rebuilding the front suspension on my 70 barracuda. Pulling the lower control arms to replace the strut rod bushing. The driver LCA is blocked by the splash shield under the frame on that side. How do you remove the splash shield without damaging the part? It does not look like a screw or bolt, but the shield is very tight to the bottom of the frame so I don't think it is some sort of spring click thingy.
Thanks for the help!
Re: E-body frame splash shield removal [Re: davenc] #2893944
02/28/21 01:34 AM
02/28/21 01:34 AM
WA
tman Offline
tman  Offline
WA
Re: E-body frame splash shield removal [Re: tman] #2893962
02/28/21 05:44 AM
02/28/21 05:44 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
1970 E had rivets that you have to drill off. 71-up had bolts.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: E-body frame splash shield removal [Re: moparmarks] #2894001
02/28/21 10:59 AM
02/28/21 10:59 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Excellent, thanks to you both!
