EFI port injection on a tunnel ram. #2893509
02/26/21 08:34 PM
02/26/21 08:34 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
anybody running efi port injection on a tunnelram? I'm interested to see some pics of how you did it. Or if someone knows a guru who knows his stuff on how to accomplish this kind of upgrade would be great too. Thanx.
Re: EFI port injection on a tunnel ram. [Re: rebel] #2893511
02/26/21 08:40 PM
02/26/21 08:40 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have wondered about port injection on my rig but I wanted to go with the Edelbrock port intake with a large throttle body.
Gus beer
64 Plymouth Savoy
Dana 60
Re: EFI port injection on a tunnel ram. [Re: fourgearsavoy] #2893514
02/26/21 08:53 PM
02/26/21 08:53 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
I have a 400 block & they dont make these for B engines unless I fit Stage 6 heads. Not going to happen, but I have bought a tunnelram to match my combo so I'm looking at what common rail systems guys have done to go EFI.
Re: EFI port injection on a tunnel ram. [Re: rebel] #2893538
02/26/21 10:19 PM
02/26/21 10:19 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Most any competent shop can convert a TR to port injection....I ran one with a bug catcher on my Hemi for years....Pretty bad as$ setup....Now a days, there are lots of options. You don't even need to convert the intake anymore, just run dual TB's...Super simple.
Re: EFI port injection on a tunnel ram. [Re: Dragula] #2893553
02/26/21 11:18 PM
02/26/21 11:18 PM
AndyF Offline
AndyF  Offline
Yes, a dual Sniper setup is the easiest install. If you want true port injection then the price goes up significantly. The tunnel ram will need to have bungs installed for the injectors and you'll need to buy throttle bodies to control the air as well as an ECU to run it.
Re: EFI port injection on a tunnel ram. [Re: AndyF] #2893555
02/26/21 11:23 PM
02/26/21 11:23 PM
Dragula Offline
Dragula  Offline
My old setup from way back before efi was a thing....
https://www.youtube.com/watch?v=-AXRHXSV5Jc
Re: EFI port injection on a tunnel ram. [Re: Dragula] #2893575
02/27/21 12:54 AM
02/27/21 12:54 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
this is the kind of set up i'm thinking of. What throttle bodies did you use on this?
Re: EFI port injection on a tunnel ram. [Re: rebel] #2893626
02/27/21 09:56 AM
02/27/21 09:56 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had a Holley Pro Dominator Tunnel ram setup for port EFI for my W2 small block. The only issue I had that I didn't think about was the fuel rails got right in the way of where the traditional bell crank style linkage would go. My solution to that wasn't my favorite but it works. I used the 4500 top for it and put adaptors on it for my 4150 throttle bodies, this allowed me to turn them inline and make a very simple throttle linkage. I don't have a pic of the linkage but its a lokar throttle cable on the front throttle body and a link connecting the two throttle bodies off of the bottom most hole in the linkage arm.
Hindsight 2020(or 2018?) I would have used two 4500 series throttle bodies instead of the adapter setup. I already had one 4150 throttle body so it was easy to just buy another. But looking back I would have just put 4000CFM of throttle body on it and never looked back. Monte Smith used to say that you can't have too much air for EFI and I have seen lots of things to support that. I have a barometric pressure sensor and was able to see that my little 416 was still pulling a vacuum on the single 4150 1000CFM throttle body, that is what made me want to try the tunnel ram.
68 Barracuda Formula S 340
Re: EFI port injection on a tunnel ram. [Re: Bad340fish] #2893642
02/27/21 11:13 AM
02/27/21 11:13 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Port injection with a tunnel ram is defeating the purpose of the tunnel ram. Not needed if you have port injection. Just get an intake that is set up for it or have bungs welded in. How about this option...
Re: EFI port injection on a tunnel ram. [Re: Moparite] #2893665
02/27/21 11:54 AM
02/27/21 11:54 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
For clarity then, please share the purpose(s) of a TR.
Here is my road race stroker SB TR. This pic is during the build. A few details not exactly obvious, I added a spring loaded pop off valve on the crossover, the fuel rails are plumbed parallel to help equalize fuel temps and pressure, the front rail crossover has an upward arc to assist trapping air in line to soften pressure pulses, I did some lightening milling on the fuel rails and TR as its porky weight wise, and in a road race application way above the COG, I cut out the rather heavy center ribbed stock TR valley cover, and replaced it with less heat transferring Ti ( the pic shows a CF/honeycomb, which I nixed) and way lighter, I epoxy coated the internal water coolant passages to reduce heat transfer into manifold, I added rear head supplementary coolant lines, ( a dubious mod I likely would not repeat), and added gold reflective mylar on outside of bottom of the intake runners.
Re: EFI port injection on a tunnel ram. [Re: Moparite] #2893667
02/27/21 11:58 AM
02/27/21 11:58 AM
Dragula Offline
Dragula  Offline
My old setup
Re: EFI port injection on a tunnel ram. [Re: Dragula] #2893669
02/27/21 12:00 PM
02/27/21 12:00 PM
Dragula Offline
Dragula  Offline
These are a lot of fun...
Re: EFI port injection on a tunnel ram. [Re: rebel] #2893670
02/27/21 12:02 PM
02/27/21 12:02 PM
Dragula Offline
Dragula  Offline
The bug catcher IS the throttle body....
Re: EFI port injection on a tunnel ram. [Re: Moparite] #2893694
02/27/21 12:50 PM
02/27/21 12:50 PM
AndyF Offline
AndyF  Offline
Yes that is a good point but most likely beyond the capabilities of the average racer. The Pro Stock teams have struggled with EFI tunnel rams. I think there is a lot of debate about where the injectors should be placed and stuff like that but the average guy isn't going to notice it much. The best shapes appear to be the LS stuff with the big forward facing throttle body but many racers want a more traditional look. And tunnel ram EFI setups do work pretty well up past 1500 hp so they do work just fine for almost all bracket racers. Might not be perfect but it is a fairly inexpensive solution that makes excellent power.
Re: EFI port injection on a tunnel ram. [Re: Dragula] #2893725
02/27/21 02:26 PM
02/27/21 02:26 PM
my own world
theraif Offline
theraif  Offline
my own world
always liked that look
Re: EFI port injection on a tunnel ram. [Re: AndyF] #2893741
02/27/21 02:57 PM
02/27/21 02:57 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
A lot of the intakes on modern efi v8's are tunnel rams, just the ports wrap around the plenum for tighter packaging. The injector placment is always a compromise between emissions, driveability, power and power band. The farther the injector is away from the port, the more time there is for the gas to evaporate and cool the charge, but the you have to pay attention more to runner design and velocity. The closer it is the easier it gets to tune idle, but the the more overlap on the engine then gives the effect of fuel stand off and hiccups like that in parts of the intake, you quickly learn where the port flow stalls.
When I built a ram stack intake for the pport rotary, I built the lower intake section multiple differnet ways, with a power band from 5500 -11,200, the injectors needed to be 16" from the port exit for best power.
Re: EFI port injection on a tunnel ram. [Re: Dragula] #2893748
02/27/21 03:12 PM
02/27/21 03:12 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
Is it just as simple as hooking up a TPS and Mass air flow sensor ?
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
Re: EFI port injection on a tunnel ram. [Re: Taylor] #2893779
02/27/21 04:13 PM
02/27/21 04:13 PM
AndyF Offline
AndyF  Offline
No mass flow sensor required. Just need the TPS and a MAP sensor located in the manifold. The bug catchers work fine for race engines but they aren't great for a street engine since they tend to leak air at idle. There might be someone making a high quality one with really nice throttle plates that seal up nice so you can set the idle speed but I've never seen them. The ones I've worked on are leaky so you end up with a high idle speed that can change a fair amount between cold and hot idle.
Re: EFI port injection on a tunnel ram. [Re: AndyF] #2893794
02/27/21 04:52 PM
02/27/21 04:52 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The port injection on a tunnel ram gets the RAM effect of a tunnel ram without all the distribution and cold start issues of dual carbs. You do lose some of the cooling of the charge but that is true with any port EFI system. Even with dual throttle body EFI you could still have distribution problems just like with a carb.
As far as the bug catcher goes they do make some street friendly ones, even ones that have progressive throttles to help tame them down on the street. There has been several magazine articles on Glen Hunters Drag Week 56 Chevy, I am sure one of them mentions the blower and EFI setup. The car is now twin turbo.
Re: EFI port injection on a tunnel ram. [Re: Bad340fish] #2893799
02/27/21 05:03 PM
02/27/21 05:03 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
On second thought it looks complicated!
