Back spacing
#2893413
02/26/21 03:22 PM
02/26/21 03:22 PM
Posts: 935 Elizabethtown, KY
6T9Hemi
Elizabethtown, KY
What is the max back spacing you can run on a 69 B body with Dana 60 and what is the max wheel width?
1969 340 4 Speed Swinger R4, black vinyl, white butt stripe, 3:91
Re: Back spacing
[Re: 6T9Hemi]
#2893438
02/26/21 04:08 PM
02/26/21 04:08 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
Is it the stock a stock Dana 60 for that car and are the leaf springs still in the stock location? The back spacing will vary depending on the wheel width used, example a 8 inch wide wheel with 4.0 inch back spacing will have similar clearances as a 10 inch wide wheel with 5.0 inch back spacing except the wheel lips will be 1/2 inch closer on both sides to the cars body and or suspension parts. A 8.0 inch wide wheel with 6.0 inch back spacing may rub the inner wheel wells, hope this helps
Re: Back spacing
[Re: moparmarks]
#2893520
02/26/21 09:27 PM
02/26/21 09:27 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
68 Charger 15x10 4 7/8 Back space, 325-50-15 outer lip rolled, stock width D60
