Re: What's too heavy for a Powerglide? [Re: n20mstr] #2893429
02/26/21 03:48 PM
02/26/21 03:48 PM
NY
challenger451ci Offline OP
NY
Originally Posted by n20mstr
Originally Posted by challenger451ci
Thanks for all the replies! I have a second gear leave CRT valve body that I had some issues with the 2-3 shift. It would drive right through the converter on the sauce on the shift(dropped ~500-600rpm). I put an A&A in and the shift drop is now ~800-900rpm on the sauce. Its been back to CRT for a change, but I haven't put it back in. Maybe I'll try leaving in 2nd and see if it likes it before going through the work of changing to a glide or TH400. I think the car needs about a 4.30 to make the 1/8th depending on converter slip. If Brad Watt can leave on a prepped track and not kill the 727, I think I'll be OK! I know that car makes a ton more power than my hoagie. Part of the reason for making the change is for durability.
I know when I made the change to the taller 2.28 low gear and 3.73's(8.5SLR), it made things much easier for power management. I need to be able to leave on a dirt road and generally can now, but I have to take a TON of power out to get it to leave.
You are right, Tony....I need a bigger jet! It has a 0.030n jet in it now, and I should be able to step it up a bit more to make it pull out the back half.
Just a .030??? OMG step it up to like a .052, then we are talking !!!
Hey NOW! That would wake it up....did I mention I need to be able to get down a dirt road? That might get interesting. smile
I think we'd do pretty well if we could get it to work on a 0.034 or 0.036 jet depending on the surface. Many times, my ramp is over 2sec just to keep the car north-south. On a "good" surface, we can shorten the ramp to 1-1.3sec.
Re: What's too heavy for a Powerglide? [Re: challenger451ci] #2893449
02/26/21 04:29 PM
02/26/21 04:29 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Okay, Go back and try the trans since John rectified the issue, and leave in 2nd on your current 30 jet. If it seems to be seamless, then do the typical necessary changes to accommodate MORE jet/gear changes. FROM THE GO, AND THENNNNNNN ONNNNN OUT!
"Any fool can know. The point is to understand"
- A. Einstein
Re: What's too heavy for a Powerglide? [Re: EvilB1Dart] #2893479
02/26/21 06:38 PM
02/26/21 06:38 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
What controller do you use ? Dual ramp it !
....BAD A$$ STREET CAR.....
Re: What's too heavy for a Powerglide? [Re: EvilB1Dart] #2893480
02/26/21 06:59 PM
02/26/21 06:59 PM
NY
NY
I think that's the way to go. It'll only be a set of gears, which I know I need anyway and I can see how happy it is with a lot less SLR. Wallace Calcs puts me at about 950hp on a 0.030 jet. I'd like to be able to throw another 100hp at it without making a mess of the 727. You guys think that's doable?
Thanks again for the help!
Re: What's too heavy for a Powerglide? [Re: an8sec70cuda] #2893481
02/26/21 07:04 PM
02/26/21 07:04 PM
gregsdart Offline
gregsdart  Offline
Originally Posted by an8sec70cuda
Originally Posted by gregsdart
Just speculating hear. With optional 1st and second straightcut gears available for the TF, could it be made to do the job and be as efficient and cheaper than converting to a glide?
I don't think there is a low enough (numerically) 1st gear available for a 727 to work very well in an application like this.
I'll try the 2nd gear leave VB from Cope in my 727 before I switch transmissions, but I'm leary of it b/c of my car's weight. I think I'd have to put a lot more rear gear in it to keep it from being such a dud and lugging the motor down bad.
There are higher second gear ratios. Somewhere around 1.7 to 1.8? Lofgren Auto had some on the shelf when i was there a week ago.
Re: What's too heavy for a Powerglide? [Re: n20mstr] #2893482
02/26/21 07:06 PM
02/26/21 07:06 PM
NY
NY
Edelbrock. We do run a dual ramp which has been a big help. Depending on the surface, we leave on anywhere from 25-30% and hold the initial ramp pretty flat(35-45%) at 0.7-1.2. 2nd ramp might have to stretch out 1sec or more too. Some of the airports are literally pebbles mid track so no sudden moves or you're sawing at the wheel... smile
Re: What's too heavy for a Powerglide? [Re: challenger451ci] #2893518
02/26/21 09:19 PM
02/26/21 09:19 PM
N
n20mstr Offline
n20mstr  Offline
N
When I had 440-1 heads , and 528 (4.15 x 4.5) I used to leave on a plate with a .070 jet and progressed a fogger ( .036n .026f) at 3300lbs it would run 5.30’s at 130- 133 . That’s was 3.70 rear and 3 speed t400 stock ratios .
If I was you I’d be looking at a plate or ? Something for a second stage or a better controller and more jet in the kit you have .
Fastest I went with a 727 was 8.38 @ 160 . That was at 3550 lbs , sorry but I don’t remember the 1/8 numbers . I’m sure a 727 can handle more than 950 . Only weak part of the 727 is the sprag , and that’s more about breaking it on the starting line than downtrack
It’s really do you want to invest in a 727 ? Eventually you will outgrow it . Best for you might be a glide with a 1.82 or 1.78 first and a dump valve to help with the 1-2 rpm drop
I have a OEM case t400 from rossler , I called him to just get a 2nd gear leave valve body , and I ended up with a Reid case 2 speed $$$$$ 1.49 first with his dump valve set up
Re: What's too heavy for a Powerglide? [Re: n20mstr] #2893621
02/27/21 09:29 AM
02/27/21 09:29 AM
NY
NY
I like the dump valve idea. That seems like it would give me some options on the shift to keep the motor happy and down low if we need to adjust a bit. Based on how the car works now at 8.5 SLR, my gut tells me 7-7.5 SLR would be about right. That would be 1.68-1.8 ish low gear that you guys are recommending with a 4.30 out back. I know I can throw a lot more at it down low with a much lower SLR, but I worry it's going to be a fine line between getting it rolling and too much wheel speed too soon. The easiest way to prove or disprove that is to try the 2nd gear leave I already have and see how it reacts then I can choose the right path.
I've been kicking all this around in my head for the last few weeks and I really appreciate you guys steering me.
And yes, a second kit would also get me the few mph I need to stay out on the much lighter turbo cars!
