Help with a '68 fender tag please #2893125
02/25/21 06:16 PM
02/25/21 06:16 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
I have decoded most of my '68 R/T fender tag, but having problems with lines 2 & 3. If someone would finish decoding this for me I would greatly appreciate it.
Sorry, having a little difficulty getting the two lines to line up.
12345678 AX TRM PNT UBS
9 0 8 48 S6B QQ1 U W
19 = Wide Sill Moulding
30 = Body Belt Moulding
78 = ???
AX = 48, 3.32 Suregrip I think
TRM = S6B - interior stuff I think
PNT = QQ1 Bright Blue Metallic
UBS = U W ???, nothing under the letter "B"
Re: Help with a '68 fender tag please [Re: 330Scott] #2893143
02/25/21 07:10 PM
02/25/21 07:10 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
CAR: Dodge Coronet R/T 2 Door Convertible
ENGINE: 440cid 4-bbl HP V8
TRANSMISSION: 3-Speed Automatic
TIRES: F70x14 Red Side Wall, Steel Belted
BUILD DATE: October 16.
AXLE: 3.23 Rear Axle Ratio, Sure Grip
INTERIOR: Sport Trim Grade, Vinyl Bucket Seats. Light Blue Interior.
PAINT: Monotone Bright Blue Metallic Paint.
OTHER: Light Blue Metallic Upper Door Frame Color. White Horizontal Accent Stripe.
MOLDINGS:
19: Wide Sill Mouldings
30: Body Belt Mouldings
78: Wheel Lip Mouldings
ABC OPTIONS:
H1: Power Brakes
R1: AM Radio
T7: Tachometer
X2: Tinted Windshield Only
Y2: White Convertible Top
abc OPTIONS:
a6: Console
b4: Bucket Seats
m6: Driver's Outside Remote Operated Mirror
this is from http://www.mymopar.com/index.php?pid=85
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: Help with a '68 fender tag please [Re: Savoy1964] #2893157
02/25/21 07:47 PM
02/25/21 07:47 PM
Eyewa
330Scott Offline OP
330Scott  Offline OP
Eyewa
Got it. Thank you.
Once you posted the TRM & UBS, I was able to break them down and see what each character meant. Sport, buckets and light blue interior for example.
Appreciate it.
Also, there is no mention of the radiator on the tag and some of the tags I looked at had a code under the "A". This car has an incorrect rad that I want to replace. Thinking I need the 22" 2898045 rad.
Re: Help with a '68 fender tag please [Re: Savoy1964] #2893258
02/26/21 12:06 AM
02/26/21 12:06 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
TIRES: F70x14 Red Side Wall, Steel Belted GOODYEAR SPEEDWAY
SCHEDULED BUILD DATE: October 16.
