Belt Tension #2892635
02/24/21 11:40 AM
02/24/21 11:40 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
440 dual belts with A/C. Obviously not a matched set of belts. How are you guys putting tension on the alt to tighten these belts? The crow bar/pry bar is just not cutting it.
Grandma always said I had "hands of gold"!
Re: Belt Tension [Re: CHRGR69] #2892665
02/24/21 12:57 PM
02/24/21 12:57 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
If the pry bar isn't getting them tight enough then get a matched set of belts
Re: Belt Tension [Re: stumpy] #2892673
02/24/21 01:32 PM
02/24/21 01:32 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
If the twin belts are not a matched set--likely one is stretched/worn a little more than the other--you will likely never get there.
Here at work we have HVAC units that run 4 or more belts on sheave-style pulleys.. If one belt gets broken or damaged we always just replace all 4 as a set, because if you don't you'll never get them to tension evenly and then you will get slippage. If you are having to crank that hard to try to get them to tension, you are risking damaging other things (bearings) just to save a couple bucks on belts. Not worth it.
Also, make sure the pulleys are not glazed. Roughing them up with emery cloth can sometimes solve minor slipping problems.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Belt Tension [Re: stumpy] #2892693
02/24/21 02:14 PM
02/24/21 02:14 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
From whom/where??
Re: Belt Tension [Re: CHRGR69] #2892750
02/24/21 03:53 PM
02/24/21 03:53 PM
Grand Prairie,Texas
Grand Prairie,Texas
Do an online search for matching belts.
Re: Belt Tension [Re: stumpy] #2892757
02/24/21 04:10 PM
02/24/21 04:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Gates V80 series are designed to be matched to a tight tolerance.
Re: Belt Tension [Re: CHRGR69] #2892777
02/24/21 05:30 PM
02/24/21 05:30 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
CHRGR69 - Also check the pulleys the make sure the sides where the belts ride, are straight and not dished or bowed.
Ron
