2017 Ram 1500 bearing #2892711
02/24/21 02:46 PM
02/24/21 02:46 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Who has a Timken carrier bearing # for a 2017 ram 1500?
Want to put a posi in and need new bearings.
They want 150.00 per bearing at the dealership CAN.
Keep in mind that this is a ZF rear they came out in 2011
Mopar # is 683402501AA.
Matt
Re: 2017 Ram 1500 bearing [Re: MattW] #2892761
02/24/21 04:30 PM
02/24/21 04:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
This is your number 68340251AA. What is the application?
Re: 2017 Ram 1500 bearing [Re: NITROUSN] #2895259
03/03/21 03:26 PM
03/03/21 03:26 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So after talking to Randy's ring and pinion the carrier bearings are the same as the earlier ones.
Timken JLM 704649 bearing and JLM 704610 race
They only went to metric bolts and a different pinion.
Matt
