Re: Cast Iron look alike paint
[Re: A12]
#2892095
02/23/21 05:10 AM
02/23/21 05:10 AM
Posts: 21,528 N.E. OHIO, USA
A12
N.E. OHIO, USA
Another alternative if you find the cast coat too dark is to use VHT Aluminum Coat. A comparison of VHT aluminum coat (left) and VHT cast coat (right) I never applied the cast coat to look as dark as in this comparison.
[Re: A727Tflite]
#2892097
02/23/21 05:42 AM
02/23/21 05:42 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
A good place to start is here for consideration of various colors of silver. It's no small matter that none of the parts mentioned are made of cast iron. The knuckles are steel forgings with a black oxide appearance, not any variation of silver or bare metal. New front end parts such as pictured show the color needed which is probably better done with actual black oxide or gun bluing than paint. Search You Tube videos for "black oxide", or you may try mixing paints in shades of black and dark gray. Black oxide resists red rust and is a viable finish coat if lightly greased or oiled periodically during engine oil changes. I use a brush and a 50-50 solution of Cosmoline and paint thinner. Lower control arms are assemblies made mostly of press-formed steel sheet, but there are also forgings and rivets which are not all the same color. It's well known that lower control arms are mostly Cosmoline coated, and there are a lot of posts about that. Click on the special enhanced Google search box at the top of this page. Upper control arms are wholly made of formed steel sheet in some shade of silver, and they will be in a dark place on a finished car. As Lilly says on his web site in the first sentence above, you should know that silver paints change their appearance depending on the amount of light. Therefore you should evaluate your paint tests in a light condition similar to how the part will be viewed in a finished car.. Save your Eastwood cast iron paint for your wheel cylinders and 4-speed case.
[Re: kentj340]
#2892147
02/23/21 10:09 AM
02/23/21 10:09 AM
Posts: 3,089 Michigan
A727Tflite
Thanks for all the replies, appreciate your feedback. Yes, I know how the parts are made and what material, just a place to start.
Not a restoration by any means but just want it to look close to stock.
Mike thanks for the pics - gives me an idea what to possibly use.
[Re: NITROUSN]
#2892241
02/23/21 01:12 PM
02/23/21 01:12 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Flash is making this look shiny. It’s not. The intense camera flash is causing the shiny reflection This is from Troy’s old thread i linked to above: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/28033/1.htmlThese are spray grey with an extremely light black spray fog over them. ...then satin clear to protect.
[Re: 76Beeper]
#2892390
02/23/21 06:14 PM
02/23/21 06:14 PM
Posts: 1,978 USA
Suregrip391
USA
I like the Seymour cast iron as well. It goes on so nicely.
[Re: RP's R/T's]
#2892474
02/23/21 09:44 PM
02/23/21 09:44 PM
A727Tflite
has anyone done the body of a trans? On an auto trans I have used the Seymour alums blast - looks very nice.
[Re: A727Tflite]
#2892476
02/23/21 09:46 PM
02/23/21 09:46 PM
A727Tflite
Going to have to buy Seymour Cast Blast after seeing that 8-3/4” housing for my 62 and 67.
Thanks for the links kentj340. And yes, I agree on the unique color of the front end parts.
Thanks Steve for those pics of the steering knuckles, caliper mounts and info.
