Taillight bulbs glow when other lights are on.. "leak"?
#2892035
02/22/21 10:01 PM
02/22/21 10:01 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I was checking the bulbs and sockets of my Satellite lights today and had my son try the reverse lights, brakes, running lights, etc while I watched what worked or what didn't...
One thing was really weird - I had the lenses off for cleaning so I could for the first time watch what the individual BULBS were doing up close..
Applying the brakes, the filament of the Running lights and the Reverse lights also came on - but just glowing slightly - as if some voltage was "leaking" to the other filament.. so I looked for the same thing in other conditions.
- In Reverse, the brake and running light bulb also glows dimly, as if voltage is "leaking".. - Turning the Running or Headlights on and everything looks normal, no other bulbs glow.. - Brake lights, like I said above, they "leak" voltage to the other Running light and Reverse light bulbs.. - The brightness on the other bulbs would increase if I pulled one of the dimly glowing bulbs, so that's a "load" on the circuit.. obviously.
How do I start troubleshooting this to find the "leak"? Or is this somehow normal? I stink at electrical issues, but I usually succeed with help.
The wiring all looks decent enough, but could there be worn insulation in the wire loom and a small amount the power is crossing over from one wire to the others?
The fuses were all cool to the touch. The FSM doesn't mention it. The Wiring diagram doesn't reveal much. The wiring connectors to the Light, Reverse and Brake switches looked good. Each switch made good continuity.
Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Taillight bulbs glow when other lights are on.. "leak"?
[Re: dOrk !]
#2892111
02/23/21 08:37 AM
02/23/21 08:37 AM
Posts: 10,707 North Dakota
6PakBee
North Dakota
Another vote for poor ground.
[Re: Andrewh]
#2892306
02/23/21 03:05 PM
02/23/21 03:05 PM
67SATisfaction
Albany, NY
Thanks guys,
YOU ARE ALL CORRECT!!
I put on my Big Boy pants and a headlamp and went to work on it early this morning. I used jumper wires, a continuity device and volt meter to trace how far the +12V power was getting, all the way around to the ground.. Then used the continuity device to isolate the problem to a Ground wire screwed to the sheetmetal - there wasn't continuity across the connection. Wire brushed it clean, gooped a little anti-corrosion lotion on it and the problem vanished.
That solved one side, and I found the other side was the exact same thing.
Cheers, - Art
[Re: A990]
#2892469
02/23/21 09:23 PM
02/23/21 09:23 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
I've run into ground issues with lighting so much, I've reached a point where I ground every light housing. I really like the replacement light sockets with the ground tab.
I now will clean a place at the front, the rear, and at the bottom of the dash that I make ground points. I'll find a pinch weld ares that is pretty easily accessible, then I remove the paint down to shiny metal, then I will drill a 1/4" hole and add a 1" long bolt with a nut and flat washers if there is room. I stick the bolt through the hole and run the nut up tight against the metal. Then I add a 1/4" eyelet to each ground wires for every light, or anything else that needs a good ground. Those eyelets go against the tightened nut, then I add another nut and tighten it down. Presto, a very good ground that lasts at least 5 years, you can even use it as a ground to test stuff. When the bolt becomes degraded, or has an issue, I will simply replace the 1/4" bolt, clean up the mounting surface again, and change the eyelets if needed, with another all new setup. Its cheap, easy, and works very well. Gene
[Re: poorboy]
#2892480
02/23/21 09:55 PM
02/23/21 09:55 PM
RapidRobert
On your jumper to check the ground stick a thin pin to make contact with the actual bulb metal case
