Re: Burst plate material
[Re: 67_Satellite]
#2891679
02/21/21 09:43 PM
02/21/21 09:43 PM
Posts: 2,151 Fancy Farm Ky
wyoming
Fancy Farm Ky
Doug, Honestly a beer can is probably to thick, most engineered burst reliefs are very thin and ussually weakened in the center, if you wanted to you could test them fairly easily with a 2 to 3 inch piece of pipe with some fab work on one end, and a cap screwed on the other. One of the respected engine builders on here mentioned, on a thread a bit back, using plastic bolts to bolt the Indy intakes we use together with plastic bolts, I checked and the bolts are easy to come by and really very reasonable, I haven't ordered any yet but I do plan on getting some for my car, I think they might work? Opinion? You can buy those in several grades rated by pressure.
[Re: wyoming]
#2891718
02/21/21 11:57 PM
02/21/21 11:57 PM
Posts: 22,696 Bitopia
jcc
Bitopia
The problem I see with the plastic bolt solution is plastic tensile strength is very temp dependent, meaning your protection level might vary widely. There are engineered low profile alum burst panels available. I used a spring loaded burst valve on my TR. I think your intention is a smart idea.
[Re: jcc]
#2891735
02/22/21 01:35 AM
02/22/21 01:35 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
what about aluminium supercharger/blower bolts ? They are designed to shear on a large back fire .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dvw]
#2891790
02/22/21 10:25 AM
02/22/21 10:25 AM
Posts: 4,206 New York
polyspheric
New York
Score a big "X" in the center.
Boffin Emeritus
[Re: dvw]
#2892117
02/23/21 08:53 AM
02/23/21 08:53 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
I don't like rupture diaphragms for a number of reasons. What I've seen in my short and uneventful life is that if you have an unstable process, you will pop the diaphragms repeatedly. What then happens is the user uses progressively thicker and thicker diaphragms until you lose any protection you have. The only time I ever used rupture diaphragms was in conjunction with a relief valve when zero leakage was necessary or as protection as a last resort.
Rupture diaphragms are not precision devices like a spring loaded relief. I've seen test results on identical rupture discs and the simple ones without a cutting bar failed in a range,not at the same pressure. Have you got a picture of your current arrangement? There have to be other options.
[Re: Al_Alguire]
#2892252
02/23/21 01:29 PM
02/23/21 01:29 PM
jcc
Bitopia
This latest solution, can it possibly lock the throttle linkage when the nylon bolts fracture and keep fuel entering the motor?
[Re: DoubleD]
#2892394
02/23/21 06:21 PM
02/23/21 06:21 PM
6PakBee
North Dakota
Here's an old thread. Crossram Burst PlateThe Wilson offering is along the lines of what I was thinking. May still be too tall for your application, about 1 1/4" high.
