Page 2 of 3 1 2 3
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: cudaman1969] #2891253
02/20/21 10:59 PM
02/20/21 10:59 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Originally Posted by cudaman1969
45 years ago couldn’t keep oil pan bolts from coming lose or falling out on the race car, on a whim I looked in a service manual, used the torque and never came lose again. Long story short I torque EVERYTHING I can get to at factory spec.
I used to have trouble with transmission pans. After I found we had an inch pound wrench I used the spec, typically 12 in lbs, found it took several rounds to get them all tight at once, no more leaks.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: 3hundred] #2891283
02/21/21 12:55 AM
02/21/21 12:55 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
About 30 years ago I lost the ability to be able to know how tight bolts were by hand tightening. Torquing everything is a royal pain. Over the last 15 or so years, I don't do much stuff that requires specific torque anymore. Just one of several reasons I became a welder. Gene
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: poorboy] #2891295
02/21/21 02:55 AM
02/21/21 02:55 AM
I remember a older Service station mechanic telling me that he had calibrated elbows on most tightening he did on cars in that stations bays.
I will use a inch lb. torque wrench and convert the lighter ft. lbs. into inch lbs. like using 23 Ft. Lbs. on 5/16 bolts, 23x12=276 inch lbs. 20x12=240 + 3x12=36. 36+240= 276
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: dOc …] #2891304
02/21/21 06:47 AM
02/21/21 06:47 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Heads, rods and mains here down under !
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Hemi_Joel] #2891331
02/21/21 09:27 AM
02/21/21 09:27 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by Hemi_Joel
Originally Posted by 6PakBee
I torque everything that has a specification. I find that even after decades I tend to over tighten smaller fasteners (< 3/8" or so) and under tighten larger fasteners (> 3/8" or so). I've gone to grade 8 on any 1/4" bolt as I pop the stock fasteners like candy. Intake gasket end rails on a BB as one example. The only notable exception is the oil pan. That I use gasket compression to know when to stop.
About the same here plus I use a torque wrench on the air cleaner wing nut, hose clamps, and trim screws. luck laugh2
What is the torque spec on an air cleaner wing nut, hose clamps, and trim screws? After all, you said you used a torque wrench to tighten them, you must know. smirk
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: 6PakBee] #2891345
02/21/21 10:15 AM
02/21/21 10:15 AM
Florida STAYcation
dOc … Offline OP
The village idiot's idiot
dOc …  Offline OP
Florida STAYcation
I’m surprised....
NO one mentions the critical torque spec of the ......
Muffler bearing
Maybe the apimp from Bend oVeR can check in xmaseek
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: dOc …] #2891348
02/21/21 10:19 AM
02/21/21 10:19 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Quote
I find a correlation between the lack of using a torque wrench and leaky valve covers and oil pans.
Quite the opposite for me. They are the only ones I have found that needed hand tightening instead of a torque wrench. All seemed to be too loose.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: mopars4ever] #2891350
02/21/21 10:22 AM
02/21/21 10:22 AM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
Oil pan bolts?
Did you apimp THROW OUT the special nyLock bolts tsk
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: dOc …] #2891413
02/21/21 11:57 AM
02/21/21 11:57 AM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I use a torque wrench on all mechanical assemblies where I can actually gain enough clearence to do so. When I can't, it bothers me!
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: 19swinger70] #2891430
02/21/21 12:29 PM
02/21/21 12:29 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I think you need to be more specific. Putting together older iron is completely different than the late model stuff. Not following specific torque specs/sequences on late model stuff(especially TTY bolts) will guarantee failures.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: Dcuda69] #2891491
02/21/21 02:15 PM
02/21/21 02:15 PM
moparx Offline
moparx  Offline
crank 'em down till they strip or break, then back 'em off 1/2 turn........... devil boogie whistling
beer
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: dOc …] #2891625
02/21/21 07:32 PM
02/21/21 07:32 PM
IMGTX Offline
IMGTX  Offline
Rod, main, & head bolts - yes
Lug nuts on any import or an American car newer than mid 80's. Yes
Exotic unfamiliar engine parts like Cam Phasers or some other unusual item that looks like it could warp under too much pressure, I look up and torque to spec too.
Anything else I will torque with experience and the industry standard spiral sequence.
I never thought of anything else having a torque spec until I watched a terminator movie and Arnold used a torque wrench on a starter. I thought that's weird and then it hit me, oh yeah there is probably a spec for everything. LOL
I also only use Red threadlocker (Permanent) and never blue (Temporary). Especially on cam bolts, even if it isn't required.
I also incrementally torque nearly everything and never tighten any one bolt until all the bolts are started and run most of the way in. I can not tell you how many newbie mechanics just start popping in bolts & tighten away, and then they have to loosen them all to get the last few in.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: mopars4ever] #2891628
02/21/21 07:44 PM
02/21/21 07:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by mopars4ever
Quote
I'm thinking of the ones reefed down so hard that they warp the rails and never seal. Both ends of the spectrum are bad.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: 3hundred] #2891783
02/22/21 10:18 AM
02/22/21 10:18 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Same here, oil pans and valve covers too.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: justinp61] #2891801
02/22/21 10:48 AM
02/22/21 10:48 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Type of pan/cover and gasket probably matters as well. If you're using a cork gasket with a stamped steel cover, then torque spec is crucial. I've been using cast aluminum covers/pans with anti-crush gaskets now for years and don't have any issues with hand tightening. Still using a stamped oil pan, but for that I bought Andy's pan reinforcements.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: justinp61] #2891908
02/22/21 03:42 PM
02/22/21 03:42 PM
IMGTX Offline
IMGTX  Offline
#1 important thing for pans and covers is clean and check them with a straight edge. Too many gorillas work on the car before me and think tighten it until it bends the wrench and the pan.
For trans/oil/valve covers I do not use anything bigger than a 1/4" drive ratchet. Same thing with plastic intakes.
I do follow the gasket manufacturers recommendation about sealant but if it doesn't have specs I do this.
Trans pans I oil both sides of the gasket and snug repeatedly in a crisscross pattern until it feels good or the gasket starts to just barely squeeze out.
Oil pan I spread a thin thin smear of sealant on both sides of the gasket and snug repeatedly in a crisscross pattern until it feels good or the gasket starts to just barely squeeze out.
Valve covers, I use sealant on the valve cover side of the gasket and oil on the bottom of the gasket then snug then repeatedly in a crisscross pattern until it feels good or the gasket starts to just barely squeeze out.
If I have a leak I snug a little more but that doesn't happen often and it is usually when a center bolt valve cover has been bent in the middle.
The most important thing is to do what works best for you.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: MarkZ] #2891938
02/22/21 05:30 PM
02/22/21 05:30 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Pffft.... not much. usually just internal engine bolts. Head, rod, main, sometimes manifolds.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: dOc …] #2891947
02/22/21 06:15 PM
02/22/21 06:15 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Keep a “fisherman’s scale” in your tool box and every wrench becomes a torque wrench.
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: 360view] #2891951
02/22/21 06:18 PM
02/22/21 06:18 PM
Kirkland, Washington
Pacnorthcuda Offline
IF you factor the length of the wrench into the calculation!
Re: Come on ... BE HONEST...what do you properly TORQUE... ? [Re: IMGTX] #2891953
02/22/21 06:20 PM
02/22/21 06:20 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
i m a GORILLA is not uncorrect... wave
Those damn pan rails are a bummer tsk
Page 2 of 3 1 2 3
