Leaf spring bushings: polyurethane vs nylon #2887497
02/13/21 12:51 AM
02/13/21 12:51 AM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
I recently came across leaf spring bushings for the front eye that are nylon,
this is for E-body 1.500" OD bushings.
I never heard of nylon for a bushing. Will it last, or is it strictly "trick", some temporary advantage/property ?
Re: Leaf spring bushings: polyurethane vs nylon [Re: hemienvy] #2889245
02/16/21 03:11 PM
02/16/21 03:11 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Nylon would be new to me too.
Delrin is another story. Looks like nylon, but a different animal. Is that what you are seeing?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Leaf spring bushings: polyurethane vs nylon [Re: DynoDave] #2889431
02/16/21 09:31 PM
02/16/21 09:31 PM
Washington
Washington
https://www.speedwaymotors.com/AFCO-20229N-Nylon-Front-Eye-Chrysler-Type-Leaf-Spring-Bushing,23536.html
Re: Leaf spring bushings: polyurethane vs nylon [Re: hemienvy] #2889444
02/16/21 10:04 PM
02/16/21 10:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
They’ll translate more road noise and vibration from trunk area.
I noticed that just changing from rubber to poly. Nylon would be worse.
Better for handing and drag racing though.
Re: Leaf spring bushings: polyurethane vs nylon [Re: DynoDave] #2890739
02/19/21 09:01 PM
02/19/21 09:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not sure about the different animal comment, they are definitely of the same family, delrin is mainly tougher, you cant tell the difference by the naked eye.
