SFI Flexplate #2889623
02/17/21 01:41 PM
02/17/21 01:41 PM
Charlotte, NC
LSP Offline OP
LSP  Offline OP
Charlotte, NC
Have an old SBM circle track crank that has a GM rear flange on it, anyone make a SFI flexplate that will bolt up and fit to a 904 TF/converter combo?
Re: SFI Flexplate [Re: LSP] #2889742
02/17/21 07:22 PM
02/17/21 07:22 PM
HR3128 Offline
HR3128  Offline
This may work for you.
https://www.holley.com/products/drivetrain/flexplates/oem_flexplates/parts/RM-946
The crank I had in my R3/W8 motor had a chevy flange. I think this was the flexplate I used. But I had a Powerglide.
It doesn't say what the convertor bolt pattern is.
Re: SFI Flexplate [Re: LSP] #2889970
02/18/21 10:56 AM
02/18/21 10:56 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have some cranks made for Nascar that have the GM bolt pattern that I run with a 904. I had the hubs turned down to Mopar size and I might not do that again.
I also had to have the "pilot bearing" area enlarged to fit the hub on the Mopar converter. Bryant machined one crank and I had a local machine shop do the other which was a Winberg.
After many dead ends with other manufactures I had to have Meziere make me a flexplate. It does have the SFI label.
It is not perfect as it does not have quite the correct offset so I run some crank shims to make it better.
If you find a better source please let me know. You would think it would be easy to make a Mopar flexplate with a GM bolt pattern but apparently it is not.
I have attached a drawing I got from Meziere but I don't know if it properly reflects the final iteration. It had to go back at least once.
However as would be expected, Meziere was very good to work with.
Re: SFI Flexplate [Re: HR3128] #2890217
02/18/21 06:59 PM
02/18/21 06:59 PM
Charlotte, NC
LSP Offline OP
LSP  Offline OP
Charlotte, NC
Did you use a motor plate and attach the starter to it?
Re: SFI Flexplate [Re: LSP] #2890290
02/18/21 10:38 PM
02/18/21 10:38 PM
HR3128 Offline
HR3128  Offline
I used a JW Ultrabell. SBM-to-Powerglide. Starter bolted to the Ultebell. That car did not have a motorplate between the engine & trans.
