Page 2 of 3 1 2 3
Re: Marvel Mystery Oil Actually Works! [Re: Ray S] #2889843
02/17/21 10:22 PM
02/17/21 10:22 PM
Guitar Jones Offline
Originally Posted by Ray S
No, as another said it helps protect rubber parts with fine mineral oil - search for an MSDS sheet on it we see it's basically oil, mineral spirits (https://en.wikipedia.org/wiki/White_spirit) and naptha.
https://www.marvelmysteryoil.com/media/1256/marvel-mystery-oil.pdf
I wouldn't want ATF on non-trans rubber seals, but it also has fine solvents and cleans hands great.
Rick Walker Carbs assembles their rebuilds with it and recommends the quart per 20 gal for old motorhomes and trucks.
https://www.facebook.com/RonEsauRac...work-all-over-the-world/434184586659940/
ATF doesn't hurt seals, it's oil, very light weight oil. Has additional additives and cleaners but oil none the less.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Marvel Mystery Oil Actually Works! [Re: Guitar Jones] #2889891
02/18/21 12:40 AM
02/18/21 12:40 AM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Probably not, but I had ATF swell polyurethane badly due to the additives so am wary...
Re: Marvel Mystery Oil Actually Works! [Re: 360view] #2890112
02/18/21 03:24 PM
02/18/21 03:24 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted by 360view
I was told:
“never use one of these Ingersol Rand air impact guns without first squirting Marvel Mystery Oil in the air quick connector.”
It worked “Marvelously” for that.
Now that is a use I will follow. I have always used "air tool oil" for that. But when my little bottle (with drop stem) is empty, I will refill it with MMO.
When I was running Alky injection, I stored the pump during winter by filling it with MMO and putting the pump in a zip lock bag.
It helped keep the pump seal from shrinking (drying out).
Re: Marvel Mystery Oil Actually Works! [Re: Ray S] #2890152
02/18/21 04:39 PM
02/18/21 04:39 PM
Engine oil will destroy rubber motor mounts and suspension bushings as well. I would imagine it would do the same to polyurethane.
Re: Marvel Mystery Oil Actually Works! [Re: RSI700VIPER] #2890220
02/18/21 07:04 PM
02/18/21 07:04 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I recall an episode of Chasing Classic Cars and Wayne's old-time mechanic, Roger used MM to unfreeze a locked up engine in a car they had acquired. Took him several days using MM down the cylinders and gently rocking the car while in gear, to eventually free the motor. Apparently that's been his go-to method for some time. Regardless if you like the show or not, Roger's da-man and deserves major creds, especially considering he's in his 80's.
Re: Marvel Mystery Oil Actually Works! [Re: cruzin] #2890225
02/18/21 07:21 PM
02/18/21 07:21 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I had a collapsed lifter in a 350 Buick back in 1980. Threw a quart of Marvel in and in a few hours all was well!!
Ron
Re: Marvel Mystery Oil Actually Works! [Re: RJS] #2890254
02/18/21 08:33 PM
02/18/21 08:33 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Ron
Yep, I had a Aspen with rackety lifters and off the advice of a friend, poured a qrt of trans fluid in. 2 mins run time and all was well. Same results w marvel
Re: Marvel Mystery Oil Actually Works! [Re: moparjim79] #2890261
02/18/21 09:05 PM
02/18/21 09:05 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
Ron
CD2 Lifter Quiet was the best, but now unobtainium.
Re: Marvel Mystery Oil Actually Works! [Re: Ray S] #2890269
02/18/21 09:18 PM
02/18/21 09:18 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Have not seen C D in a LONG TIME
Re: Marvel Mystery Oil Actually Works! [Re: moparjim79] #2890676
02/19/21 07:21 PM
02/19/21 07:21 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I have used it in engines that have sat for years. It is good stuff. For fuel systems and engines lubricating.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Marvel Mystery Oil Actually Works! [Re: Magnumguy] #2890976
02/20/21 12:47 PM
02/20/21 12:47 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I'd like to try it on a loud lifter car at work. Do you add a quart to an engine, generally speaking? Do you add in place of one quart of oil at oil change, or change oil and refill with same amount of oil called for, plus MMO?
Facts are stubborn things.
Re: Marvel Mystery Oil Actually Works! [Re: larrymopar360] #2890988
02/20/21 12:58 PM
02/20/21 12:58 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Just throw the quart in on top of the normal level. Done it plenty of times, nothing to get scared about
Re: Marvel Mystery Oil Actually Works! [Re: moparjim79] #2891083
02/20/21 03:21 PM
02/20/21 03:21 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Re: Marvel Mystery Oil Actually Works! [Re: larrymopar360] #2891122
02/20/21 04:20 PM
02/20/21 04:20 PM
Just don't leave it in there. Change the oil and filter after a bit.
Re: Marvel Mystery Oil Actually Works! [Re: Guitar Jones] #2891140
02/20/21 05:06 PM
02/20/21 05:06 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Ohhhh. Bummer, I can't do that.
Re: Marvel Mystery Oil Actually Works! [Re: Guitar Jones] #2891154
02/20/21 05:32 PM
02/20/21 05:32 PM
PINE VALLEY
Ray S Offline
Ray S  Offline
PINE VALLEY
If the engine dirty, yes
I normally run the 413 with 6qts 20-50 and 1 MMO, as per RIck Walker
Re: Marvel Mystery Oil Actually Works! [Re: Ray S] #2891216
02/20/21 09:12 PM
02/20/21 09:12 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I'm sure it's dirty. 5.7 with over 100,000 miles and I haven't checked idle or engine hours, but for sure very high. Not the best maintenance here. It just came out of fleet for lower rad hose and I think they did oil change while there.
Re: Marvel Mystery Oil Actually Works! [Re: larrymopar360] #2891221
02/20/21 09:24 PM
02/20/21 09:24 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
AH HA! Ok, I was waiting for one of these to rear its ugly head-- this will not work on an MDS engine unfortunately, 99% of the time thats just a down right failed lifter usually taking a camshaft with it.
And not to start any kind of tinkle match, but I've ram trans fluid and MMO in oil for the duration of the life of said oil until its next change.
Re: Marvel Mystery Oil Actually Works! [Re: moparjim79] #2891440
02/21/21 12:36 PM
02/21/21 12:36 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I happen to know this poor car got ran without oil for a period. Damaged oil pan, gasket blew out....long story but it got driven back to shop with oil dumping and had to be out of oil or close to it by time it got back to shop. Nuff said on that. No it was NOT me. After this is when tap tap tap started. And remember, over 100k hard miles and tons of idle and engine hours.
Re: Marvel Mystery Oil Actually Works! [Re: RSI700VIPER] #2891442
02/21/21 12:42 PM
02/21/21 12:42 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Pilots and aviation mechanics (A&P) use it frequently for it's ability to dislodge glaze from cylinders and heads. Remember aircraft are air cooled and meticulously maintained (should be at least).
The stuff is basically a lot of mineral oil and some mineral spirits with a little bit of benzene solvents to cut oil that becomes plasticized from high heat (think outside cast iron skille)t.
Anyplace you see that crusty black stuff or amber colored buildup n parts when disassembling an engine will be cleaner if you use this stuff in oil and fuel. Using it one needs to stay up on oil change intervals and filter changes. If used on old engines checking the oil pickup screen is a good idea. I recall seeing "experienced" engines that died of oil starvation after the stuff was used and the pickup was plugged solid. Regardless wearing surfaces generally stay clean (cam lobes and lifters, cyl walls, bearings) and the area around ring lands do stay clean.
If using synthetic the best I method I recall was to put it in about 1,000 mi before a filter change, repeat every change.
My gut feeling is the benzene solvents really do the work and the mineral oil and spirits thin and mix with the oil to get the solvents into the lube circuits and carry the crud away to the oil filter.
Which reminds me use high quality filters so as to trap the crud.
Page 2 of 3 1 2 3
