Re: Marvel Mystery Oil Actually Works!
[Re: Ray S]
#2889843
02/17/21 10:22 PM
02/17/21 10:22 PM
Guitar Jones
ATF doesn't hurt seals, it's oil, very light weight oil. Has additional additives and cleaners but oil none the less.
[Re: Guitar Jones]
#2889891
02/18/21 12:40 AM
02/18/21 12:40 AM
Posts: 157 PINE VALLEY
Ray S
PINE VALLEY
ATF doesn't hurt seals, it's oil, very light weight oil. Has additional additives and cleaners but oil none the less. Probably not, but I had ATF swell polyurethane badly due to the additives so am wary...
[Re: 360view]
#2890112
02/18/21 03:24 PM
02/18/21 03:24 PM
Posts: 16,928 NC
440Jim
NC
I was told: “never use one of these Ingersol Rand air impact guns without first squirting Marvel Mystery Oil in the air quick connector.” It worked “Marvelously” for that. Now that is a use I will follow. I have always used "air tool oil" for that. But when my little bottle (with drop stem) is empty, I will refill it with MMO. When I was running Alky injection, I stored the pump during winter by filling it with MMO and putting the pump in a zip lock bag. It helped keep the pump seal from shrinking (drying out).
[Re: Ray S]
#2890152
02/18/21 04:39 PM
02/18/21 04:39 PM
Guitar Jones
ATF doesn't hurt seals, it's oil, very light weight oil. Has additional additives and cleaners but oil none the less. Probably not, but I had ATF swell polyurethane badly due to the additives so am wary... Engine oil will destroy rubber motor mounts and suspension bushings as well. I would imagine it would do the same to polyurethane.
[Re: RJS]
#2890254
02/18/21 08:33 PM
02/18/21 08:33 PM
Posts: 1,408 Central Pa
moparjim79
Central Pa
I had a collapsed lifter in a 350 Buick back in 1980. Threw a quart of Marvel in and in a few hours all was well!! Ron Yep, I had a Aspen with rackety lifters and off the advice of a friend, poured a qrt of trans fluid in. 2 mins run time and all was well. Same results w marvel
[Re: moparjim79]
#2890261
02/18/21 09:05 PM
02/18/21 09:05 PM
Ray S
PINE VALLEY
I had a collapsed lifter in a 350 Buick back in 1980. Threw a quart of Marvel in and in a few hours all was well!! Ron Yep, I had a Aspen with rackety lifters and off the advice of a friend, poured a qrt of trans fluid in. 2 mins run time and all was well. Same results w marvel CD2 Lifter Quiet was the best, but now unobtainium.
[Re: Magnumguy]
#2890976
02/20/21 12:47 PM
02/20/21 12:47 PM
Posts: 15,900 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'd like to try it on a loud lifter car at work. Do you add a quart to an engine, generally speaking? Do you add in place of one quart of oil at oil change, or change oil and refill with same amount of oil called for, plus MMO?
Facts are stubborn things.
[Re: larrymopar360]
#2891122
02/20/21 04:20 PM
02/20/21 04:20 PM
Guitar Jones
Just throw the quart in on top of the normal level. Done it plenty of times, nothing to get scared about Just don't leave it in there. Change the oil and filter after a bit.
[Re: Guitar Jones]
#2891140
02/20/21 05:06 PM
02/20/21 05:06 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Just throw the quart in on top of the normal level. Done it plenty of times, nothing to get scared about Just don't leave it in there. Change the oil and filter after a bit. Ohhhh. Bummer, I can't do that.
[Re: Ray S]
#2891216
02/20/21 09:12 PM
02/20/21 09:12 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I'm sure it's dirty. 5.7 with over 100,000 miles and I haven't checked idle or engine hours, but for sure very high. Not the best maintenance here. It just came out of fleet for lower rad hose and I think they did oil change while there.
[Re: larrymopar360]
#2891221
02/20/21 09:24 PM
02/20/21 09:24 PM
moparjim79
Central Pa
I'm sure it's dirty. 5.7 with over 100,000 miles and I haven't checked idle or engine hours, but for sure very high. Not the best maintenance here. It just came out of fleet for lower rad hose and I think they did oil change while there. AH HA! Ok, I was waiting for one of these to rear its ugly head-- this will not work on an MDS engine unfortunately, 99% of the time thats just a down right failed lifter usually taking a camshaft with it. And not to start any kind of tinkle match, but I've ram trans fluid and MMO in oil for the duration of the life of said oil until its next change.
[Re: moparjim79]
#2891440
02/21/21 12:36 PM
02/21/21 12:36 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I happen to know this poor car got ran without oil for a period. Damaged oil pan, gasket blew out....long story but it got driven back to shop with oil dumping and had to be out of oil or close to it by time it got back to shop. Nuff said on that. No it was NOT me. After this is when tap tap tap started. And remember, over 100k hard miles and tons of idle and engine hours.
