Page 1 of 3 1 2 3
rear sway bar and parts finish or coating #2889466
02/16/21 11:22 PM
02/16/21 11:22 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
What finish should the rear sway bar leaf spring plates be on a 71 e body.And actually what about the swaybar,links and frame brackets? Im assuming the entire assembly was painted black like fronts are?
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2889491
02/17/21 01:34 AM
02/17/21 01:34 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
China is the enemy.
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2889492
02/17/21 01:34 AM
02/17/21 01:34 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
This is a late 1970 Ebody (T/A)
Front sway bar: end links bolts, spacer, and washers black phosphate, U-straps, U-strap bolt black phosphate, U-strap I think black phosphate but maybe natural help
Rear sway bar: frame bracket is black, bolts zinc, end links like front,
E4A0AC78-4DA8-473D-BAA2-057DBBB12A40.jpeg0F7EC28F-52C5-4A5D-86A7-7E8A32F5CB29.jpegF84C9799-B59A-46A3-B364-2C9E5136D1CC.jpeg
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2889493
02/17/21 01:35 AM
02/17/21 01:35 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
China is the enemy.
Re: rear sway bar and parts finish or coating [Re: ogopogo] #2889494
02/17/21 01:36 AM
02/17/21 01:36 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Pics from the late Dave Walden...
China is the enemy.
Re: rear sway bar and parts finish or coating [Re: 1972CudaV21] #2889497
02/17/21 01:44 AM
02/17/21 01:44 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That just weird to me that the all those parts: stamped sheet, bolts, forged bar... all have the same color? Even if natural, differ materials have different looks.
Bolt almost always have some treatment finish to them.
Is that the 1970 4 door cuda?
Re: rear sway bar and parts finish or coating [Re: autoxcuda] #2889498
02/17/21 01:48 AM
02/17/21 01:48 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Yes, they’re from his blogs on the 4-Door Barracuda. I’m just putting them out there.
China is the enemy.
Re: rear sway bar and parts finish or coating [Re: 1972CudaV21] #2889500
02/17/21 02:00 AM
02/17/21 02:00 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Maybe the flash is doing numbers to it.
My 71 rear sway bar is unrestored yet. It’s got a lot of factory undercoating on it since it’s an undercoating car. The fame bracket does have surface rust. Maybe it was natural.
Re: rear sway bar and parts finish or coating [Re: autoxcuda] #2889606
02/17/21 12:44 PM
02/17/21 12:44 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I've been following this and dug out this NOS rear sway bar I have.
It is natural finish but shows some traces of black paint...perhaps as a preservative.
Has part number stencilled on and
Grey paint/primer also evident near the brackets.
Re: rear sway bar and parts finish or coating [Re: mccannix] #2889630
02/17/21 01:54 PM
02/17/21 01:54 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Very interesting
Does the grey primer look to be over some of that black paint ?
The one Walden did looked to have something on bar near bushing.
What’s tough is NOS parts often look a lot different than assembly line parts.
Need survivor pics also.
Re: rear sway bar and parts finish or coating [Re: autoxcuda] #2889644
02/17/21 02:44 PM
02/17/21 02:44 PM
MA
steve70 Offline
steve70  Offline
MA
Original 70 T/A
1970 Challenger T/A 4 speed
Re: rear sway bar and parts finish or coating [Re: steve70] #2889723
02/17/21 06:37 PM
02/17/21 06:37 PM
New Jersey Bada Bing
bremotorsports Offline
I have an NOS E-Body rear sway bar.
100% painted black. Everything!
Part number (sales part number in parts catalog) 3402049.
However, the number stamped in yellow ink on the bar itself is 3402043.
Bill Rolik
Re: rear sway bar and parts finish or coating [Re: bremotorsports] #2889726
02/17/21 06:47 PM
02/17/21 06:47 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Bill Rolik
Hi Bill,
Wouldn’t the assembly line parts differ?
From what I’ve read, NOS parts were usually given extra protection (paint) for a long shelf life. Customers didn’t want to buy rusty parts at the counter.
China is the enemy.
Re: rear sway bar and parts finish or coating [Re: 1972CudaV21] #2889759
02/17/21 08:14 PM
02/17/21 08:14 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content
44D6PAKCUDA  Online Content
Dave had said in one of the article on the 4 door Cuda that the rear sway bar was tin butter plated
I just re-rear the article,and Dave found the tinning butter just under the area where the busgings would sit
Re: rear sway bar and parts finish or coating [Re: 44D6PAKCUDA] #2889765
02/17/21 08:31 PM
02/17/21 08:31 PM
The original one in my car was black also.
BR
Re: rear sway bar and parts finish or coating [Re: bremotorsports] #2889782
02/17/21 09:01 PM
02/17/21 09:01 PM
Here is the stamp I had made for the number found on the bar.
Yellow ink.
BR
Re: rear sway bar and parts finish or coating [Re: steve70] #2889786
02/17/21 09:03 PM
02/17/21 09:03 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Originally Posted by steve70
Original 70 T/A
That’s from the same car I posted the three pictures above from. The FT6 T/A that Troy restored that had like 30k? So Cal miles on it.
Re: rear sway bar and parts finish or coating [Re: bremotorsports] #2889788
02/17/21 09:08 PM
02/17/21 09:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yellow ink.
BR
Do you have pics of your original bar with the part number stamp?
Is this on your orange 71 340 conv?
Re: rear sway bar and parts finish or coating [Re: autoxcuda] #2889871
02/17/21 11:20 PM
02/17/21 11:20 PM
The original bar had only the 34 portion of the number visible. Most of the paint was gone. I never took a photo.
On the NOS bar, which I acquired over 25 years ago, I have a photo of the number in its entirety. I have to dig it out, so it may be a day or so. The NOS bar has since been media blasted and painted. Only the stamp needs to be applied.
FYI, my car is a 340 auto, FE5, white top, white interior, white billboards. I have almost 100 tote bins of NOS, and most other components, including all of the fasteners have already been powder coated/painted/plated etc. as needed. Engine in process as we speak. Body/paint is last.
Bill Rolik
Re: rear sway bar and parts finish or coating [Re: bremotorsports] #2889874
02/17/21 11:37 PM
02/17/21 11:37 PM
I have also noticed that the rear sway bar bushing retainers on the the Walden car ARE THE CORRECT ONES. The retainers available today, AND the ones Chrysler serviced up until perhaps 8-10 years ago, have a flat lip around the perimeter, and are finished in black zinc. The originals have no lip, just a nice rounded shape. I had to go through a ton of them to find some that were not pitted to hell. Same deal for the retainers on the front sway bar. Finish should be phosphate. The rear shock absorber washers were originally made without the lip as well.
BR
Page 1 of 3 1 2 3
