Re: rear sway bar and parts finish or coating
[Re: ogopogo]
#2889491
02/17/21 01:34 AM
02/17/21 01:34 AM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
What finish should the rear sway bar leaf spring plates be on a 71 e body.And actually what about the swaybar,links and frame brackets? Im assuming the entire assembly was painted black like fronts are?
China is the enemy.
[Re: ogopogo]
#2889492
02/17/21 01:34 AM
02/17/21 01:34 AM
Posts: 27,453 So Cal
autoxcuda
So Cal
What finish should the rear sway bar leaf spring plates be on a 71 e body.And actually what about the swaybar,links and frame brackets? Im assuming the entire assembly was painted black like fronts are? This is a late 1970 Ebody (T/A) Front sway bar: end links bolts, spacer, and washers black phosphate, U-straps, U-strap bolt black phosphate, U-strap I think black phosphate but maybe natural Rear sway bar: frame bracket is black, bolts zinc, end links like front,
[Re: ogopogo]
#2889493
02/17/21 01:35 AM
02/17/21 01:35 AM
1972CudaV21
Connecticut
China is the enemy.
[Re: ogopogo]
#2889494
02/17/21 01:36 AM
02/17/21 01:36 AM
1972CudaV21
Connecticut
What finish should the rear sway bar leaf spring plates be on a 71 e body.And actually what about the swaybar,links and frame brackets? Im assuming the entire assembly was painted black like fronts are? Pics from the late Dave Walden...
China is the enemy.
[Re: 1972CudaV21]
#2889497
02/17/21 01:44 AM
02/17/21 01:44 AM
autoxcuda
So Cal
What finish should the rear sway bar leaf spring plates be on a 71 e body.And actually what about the swaybar,links and frame brackets? Im assuming the entire assembly was painted black like fronts are? Pics from the late Dave Walden... That just weird to me that the all those parts: stamped sheet, bolts, forged bar... all have the same color? Even if natural, differ materials have different looks. Bolt almost always have some treatment finish to them. Is that the 1970 4 door cuda?
[Re: autoxcuda]
#2889498
02/17/21 01:48 AM
02/17/21 01:48 AM
1972CudaV21
Connecticut
Yes, they’re from his blogs on the 4-Door Barracuda. I’m just putting them out there.
China is the enemy.
[Re: 1972CudaV21]
#2889500
02/17/21 02:00 AM
02/17/21 02:00 AM
autoxcuda
So Cal
Yes, they’re from his blogs on the 4-Door Barracuda. I’m just putting them out there. Maybe the flash is doing numbers to it. My 71 rear sway bar is unrestored yet. It’s got a lot of factory undercoating on it since it’s an undercoating car. The fame bracket does have surface rust. Maybe it was natural.
[Re: mccannix]
#2889630
02/17/21 01:54 PM
02/17/21 01:54 PM
autoxcuda
So Cal
I've been following this and dug out this NOS rear sway bar I have. It is natural finish but shows some traces of black paint...perhaps as a preservative. Has part number stencilled on and Grey paint/primer also evident near the brackets. Very interesting Does the grey primer look to be over some of that black paint ? The one Walden did looked to have something on bar near bushing. What’s tough is NOS parts often look a lot different than assembly line parts. Need survivor pics also.
[Re: bremotorsports]
#2889726
02/17/21 06:47 PM
02/17/21 06:47 PM
1972CudaV21
Connecticut
I have an NOS E-Body rear sway bar.
100% painted black. Everything!
Part number (sales part number in parts catalog) 3402049.
However, the number stamped in yellow ink on the bar itself is 3402043.
Bill Rolik
Hi Bill,
Wouldn’t the assembly line parts differ?
From what I’ve read, NOS parts were usually given extra protection (paint) for a long shelf life. Customers didn’t want to buy rusty parts at the counter.
China is the enemy.
#2889788
02/17/21 09:08 PM
02/17/21 09:08 PM
autoxcuda
So Cal
Here is the stamp I had made for the number found on the bar.
Yellow ink.
BR
Do you have pics of your original bar with the part number stamp? Is this on your orange 71 340 conv?
[Re: autoxcuda]
#2889871
02/17/21 11:20 PM
02/17/21 11:20 PM
Posts: 2,901 New Jersey Bada Bing
bremotorsports
The original bar had only the 34 portion of the number visible. Most of the paint was gone. I never took a photo.
On the NOS bar, which I acquired over 25 years ago, I have a photo of the number in its entirety. I have to dig it out, so it may be a day or so. The NOS bar has since been media blasted and painted. Only the stamp needs to be applied.
FYI, my car is a 340 auto, FE5, white top, white interior, white billboards. I have almost 100 tote bins of NOS, and most other components, including all of the fasteners have already been powder coated/painted/plated etc. as needed. Engine in process as we speak. Body/paint is last.
Bill Rolik
