Adding electric choke to Eddy AVS2? (not what you think) #2888981
02/15/21 11:06 PM
02/15/21 11:06 PM
Scranton, PA
Montclaire Offline OP
Scranton, PA
So the newish AVS/AVS2 carbs from Edelbrock come in a manual and electric choke. I have the manual version and wanted to order an electric choke kit, the same as I have done with AFB carbs in the past. Apparently there is no kit available. In fact, Edelbrock says that manual AVS carbs can't be upgraded with an electric choke. I have to think this is BS - the body of the carb even has the bosses for the choke, even though it's the manual version. Has anyone figured out what's different between the two? Thanks
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889221
02/16/21 02:11 PM
02/16/21 02:11 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
That does seem odd.... work
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: DynoDave] #2889227
02/16/21 02:27 PM
02/16/21 02:27 PM
ILL
Greentween Offline
Greentween  Offline
ILL
My guess = Missing vacuum port hole for the choke pull off piston that is inside the choke body???
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889231
02/16/21 02:40 PM
02/16/21 02:40 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I have a 650 AVS2 with the electric choke, but I can't tell you what the difference is to the manual model. I just made sure I ordered the electric because a manual is a PITA. It is off the car in the basement so if you need a specific view let me know and I can pull it off the shelf.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Greentween] #2889236
02/16/21 02:56 PM
02/16/21 02:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, the mounting bosses might be there but are they drilled for vacuum?
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: John_Kunkel] #2889256
02/16/21 03:43 PM
02/16/21 03:43 PM
Scranton, PA
Scranton, PA
Do they have to be? The chokes on these are electric, not vacuum.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889304
02/16/21 05:29 PM
02/16/21 05:29 PM
Guitar Jones Offline
There are no vacuum operated chokes. OEM carbs typically have a vacuum pull off to keep the engine from being too rich after it starts. Aftermarket carbs don't typically have them and while the electric choke assemblies on these work they are less than ideal. Some carbs that were originally manual choke versions may have the bosses to mount an electric choke but may not be drilled and tapped. That of course can be rectified. Otherwise I'm not familiar with the Eddy carbs so I don't have a specific answer for you but if the bosses are there you should be able to do it. I've converted many Holley mechanical secondary carbs to vacuum secondary and vice versa. If the basics are on the casting you can modify the rest.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889305
02/16/21 05:32 PM
02/16/21 05:32 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Does it take this electric choke?
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Greentween] #2889309
02/16/21 05:40 PM
02/16/21 05:40 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Carb Side
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Greentween] #2889310
02/16/21 05:43 PM
02/16/21 05:43 PM
Well there you go. If that boss is on the carb body you should be able to drill it and make it work.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Guitar Jones] #2889314
02/16/21 05:49 PM
02/16/21 05:49 PM
Scranton, PA
Scranton, PA
Well look at that. That does look like it, wouldn't have guessed it was vacuum as well. Here are some pics for comparison. Model 1912 vs 1913
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Greentween] #2889320
02/16/21 06:06 PM
02/16/21 06:06 PM
Scranton, PA
Scranton, PA
I think that's the AFB choke and not the AVS? (EDIT - looks like they have upgraded across the board) Apparently these all have a vacuum aspect to them, last time I modified one was twenty years ago though. The AFB must have had a port plug, I don't remember drilling anything.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889326
02/16/21 06:24 PM
02/16/21 06:24 PM
Scranton, PA
Scranton, PA
Anyone know if these new AVS's use the same body tooling as the originals? I've found a few threads on adding the AFB style electric choke to an original AVS. Leave it to Edelbrock to make something simple into something difficult.
https://www.forabodiesonly.com/mopar/threads/converting-carter-avs-to-electric-choke.436453/
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889361
02/16/21 07:33 PM
02/16/21 07:33 PM
It looks like the lever is slightly different.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Guitar Jones] #2889395
02/16/21 08:38 PM
02/16/21 08:38 PM
Scranton, PA
Scranton, PA
Pretty sure I had to change the lever on my AFB - they gave you one in the kit or a whole new shaft. The position of the electric choke arm and linkage look the same AVS to AFB too.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889519
02/17/21 08:26 AM
02/17/21 08:26 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I think that the brass plug on the very top picture is the hole for the vacuum , they just plug it on a manual choke carb.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Montclaire] #2889613
02/17/21 01:08 PM
02/17/21 01:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Note the first sentence.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: B1MAXX] #2889688
02/17/21 04:26 PM
02/17/21 04:26 PM
The one that is in the base plate.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: John_Kunkel] #2889690
02/17/21 04:30 PM
02/17/21 04:30 PM
So what? Believe everything you read?
Looks to me like it can be done pretty easy. Need to change the choke blade lever, remove the vacuum plug or drill it, maybe tap the mounting boss holes as well but still very doable.
Re: Adding electric choke to Eddy AVS2? (not what you think) [Re: Guitar Jones] #2889720
02/17/21 06:24 PM
02/17/21 06:24 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
yeah in the front passenger side, below the mtg hole pattern.
