Re: Adding electric choke to Eddy AVS2? (not what you think)
[Re: Greentween]
#2889236
02/16/21 02:56 PM
02/16/21 02:56 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My guess = Missing vacuum port hole for the choke pull off piston that is inside the choke body??? Yep, the mounting bosses might be there but are they drilled for vacuum?
[Re: Montclaire]
#2889304
02/16/21 05:29 PM
02/16/21 05:29 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Do they have to be? The chokes on these are electric, not vacuum. There are no vacuum operated chokes. OEM carbs typically have a vacuum pull off to keep the engine from being too rich after it starts. Aftermarket carbs don't typically have them and while the electric choke assemblies on these work they are less than ideal. Some carbs that were originally manual choke versions may have the bosses to mount an electric choke but may not be drilled and tapped. That of course can be rectified. Otherwise I'm not familiar with the Eddy carbs so I don't have a specific answer for you but if the bosses are there you should be able to do it. I've converted many Holley mechanical secondary carbs to vacuum secondary and vice versa. If the basics are on the casting you can modify the rest.
[Re: Greentween]
#2889309
02/16/21 05:40 PM
02/16/21 05:40 PM
Posts: 211 ILL
Greentween
ILL
[Re: Greentween]
#2889310
02/16/21 05:43 PM
02/16/21 05:43 PM
Guitar Jones
Well there you go. If that boss is on the carb body you should be able to drill it and make it work.
[Re: Greentween]
#2889320
02/16/21 06:06 PM
02/16/21 06:06 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Does it take this electric choke? I think that's the AFB choke and not the AVS? (EDIT - looks like they have upgraded across the board) Apparently these all have a vacuum aspect to them, last time I modified one was twenty years ago though. The AFB must have had a port plug, I don't remember drilling anything.
[Re: Montclaire]
#2889361
02/16/21 07:33 PM
02/16/21 07:33 PM
Guitar Jones
It looks like the lever is slightly different.
[Re: Guitar Jones]
#2889395
02/16/21 08:38 PM
02/16/21 08:38 PM
Montclaire
Scranton, PA
Pretty sure I had to change the lever on my AFB - they gave you one in the kit or a whole new shaft. The position of the electric choke arm and linkage look the same AVS to AFB too.
[Re: B1MAXX]
#2889688
02/17/21 04:26 PM
02/17/21 04:26 PM
Guitar Jones
I think that the brass plug on the very top picture is the hole for the vacuum , they just plug it on a manual choke carb. The one that is in the base plate.
[Re: John_Kunkel]
#2889690
02/17/21 04:30 PM
02/17/21 04:30 PM
Guitar Jones
So what? Believe everything you read? Looks to me like it can be done pretty easy. Need to change the choke blade lever, remove the vacuum plug or drill it, maybe tap the mounting boss holes as well but still very doable.
[Re: Guitar Jones]
#2889720
02/17/21 06:24 PM
02/17/21 06:24 PM
Posts: 2,007 Apollo, PA.
B1MAXX
Apollo, PA.
I think that the brass plug on the very top picture is the hole for the vacuum , they just plug it on a manual choke carb. The one that is in the base plate. yeah in the front passenger side, below the mtg hole pattern.
