NASCAR Engines?? #2888051
02/14/21 12:07 PM
02/14/21 12:07 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What has been common experience with NASCAR engines. Primarily 358ci R5P7 engines rated at approx 820 to 830hp. What is best use racing or exotic street? What had to be changed for either situation, cam/springs, oil pump/pan, compression, or what? Seems like excellent cost/hp from a fresh engine, worth it or too much hassle? What is going price for fresh engine, not asking but common buying price??
Re: NASCAR Engines?? [Re: Blucuda413] #2888057
02/14/21 12:30 PM
02/14/21 12:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
They make a nice engine for racing.
Buddy threw one in a 68 Dart( and it was a truck restrictor plate engine) only 12 to 1 with a “ dinky” 248/258 cam in it it.
Still ran low 9.40’s at 143 or so.
Requires some front end fab work to get it to fit, but there are adapter plates available to run a 904/727 behind them.
I dont think he had 10k in the complete motor
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: NASCAR Engines?? [Re: Blucuda413] #2888062
02/14/21 12:36 PM
02/14/21 12:36 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
My Ex had a 98 Dakota with a R5P7 built by Eatmon , was sold as a 750 HP engine, had a wetsump pan, pump gas, ran a t56 behind it , went a best of 10.00, (atco in NJ) I forget the MPH on that run. the thing I hated about it it was very peaky on the street , didn't like pulling out at a light in traffic , I didn't like driving it, but at the track it was a lot of fun, I never went faster then a 10.80s in it. the EX put about 9500miles on it in the 5 years we were married , he freshened up the valves springs and clutch every spring but other then that maintenance it held up well. he pulled the R5P7 last year sold it and now is building a G3 Hemi for it.
http://www.eatmonraceparts.com/
04 Ram 4x2 11.66@ 122 4750LBS ...phat pig Moves for fully loaded truck with NA 345ci Hemi
2020 1320 Challenger....stock daily driver.
Re: NASCAR Engines?? [Re: Blucuda413] #2888117
02/14/21 01:28 PM
02/14/21 01:28 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The Honda 48mm (1.89") rod journal is a great idea for an engine never loaded at low RPM.
However, comparing it to a 2.375" (BBM) journal, the local oil pressure at the bearing surface is 20% lower at the same gauge pressure. The ratio of the journal circumferences determines the oil wedge viscosity, all the pump pressure does is "fill in the hole".
The difference decays as engine speed increases, and is harmless at power peak so a stronger relief spring won't help.
Needs thicker oil, larger pump, higher idle speed, and treat it like nitrous: no big power at low RPM.
Boffin Emeritus
Re: NASCAR Engines?? [Re: polyspheric] #2888152
02/14/21 01:59 PM
02/14/21 01:59 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I looked at this combo. Was for sale at a machine shop with engine dyno. It made over 800 HP. The power curve was not for drag racing unless you launched at 8000 and kept it the tight power bans. Definitely a cam change. Completely different mind/design set than the old purple stripe oval track cam. Roundy guy bought it before I could research any more.
Re: NASCAR Engines?? [Re: A/MP] #2888259
02/14/21 04:43 PM
02/14/21 04:43 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
My thought is that they would be tough to make work in a heavy, door slammer because of the narrow power band. They make big power at the rpm range they are designed to work at, but I don't think they make a lot of torque, and that big bore and short stroke would be tough to make work. I know some Pro Stick guys use them, but most of them don't run in a wide power band, they leave at a big rpm, and it doesn't vary much. You can buy them pretty reasonable, though, and I think it's limited application is why.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: NASCAR Engines?? [Re: Steve1118] #2888265
02/14/21 04:54 PM
02/14/21 04:54 PM
UK
rb446 Offline
rb446  Offline
UK
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: NASCAR Engines?? [Re: rb446] #2888389
02/14/21 08:20 PM
02/14/21 08:20 PM
I love 4 speed cars but they are a pain to maintain and race, especially ones like that one whiney
Re: NASCAR Engines?? [Re: Cab_Burge] #2888390
02/14/21 08:28 PM
02/14/21 08:28 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
If you are going to go down this road, buy complete.
A second hand engine will set you back around $6500+
Freshened engines tend to sell for $10-25K, depending on how many new parts are in it.
Spare parts aren't littered throughout eBay like they used to be though, so if building from parts, it get's quite expensive.
Alan Jones
Re: NASCAR Engines?? [Re: LA360] #2888526
02/15/21 07:33 AM
02/15/21 07:33 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Interesting topic...there are quite a few of these over on racing junk...
https://www.racingjunk.com/Modern-H...acing-Ernie-Elliott-Dodge-R5-Engine.html
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: NASCAR Engines?? [Re: RapidusMaximus] #2888571
02/15/21 10:30 AM
02/15/21 10:30 AM
USA
hudsonhornet7x Offline
USA
If I remember correctly the Ritter small block can be ordered to accept P7 heads. You could have a large displacement small block with the great flowing heads. Would that be an option?
Re: NASCAR Engines?? [Re: hudsonhornet7x] #2888603
02/15/21 11:23 AM
02/15/21 11:23 AM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I have a r5p7 that I put in a 69 dart with a g force 5 speed. The car has not made a pass with this engine yet. Biggest issue that I see for a true street car is the heads are so big for the cubic inch that the need rpm to make big power. The dart in the videos ran drag week in 2019 drove 1500+ miles and never even had the valve cover off.
Re: NASCAR Engines?? [Re: NoFrills] #2888706
02/15/21 01:29 PM
02/15/21 01:29 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
There was a guy that ran one on Drag Week with a manual transmission who ran fairly well.
It was a nice car with some engine set back.
It was fast but not as fast as a Brett Miller W8 engine that one its class.
Re: NASCAR Engines?? [Re: rb446] #2888715
02/15/21 01:38 PM
02/15/21 01:38 PM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
I like the telescopic steering on that Dart LOL!
"Any fool can know. The point is to understand"
- A. Einstein
Re: NASCAR Engines?? [Re: RapidusMaximus] #2888870
02/15/21 06:37 PM
02/15/21 06:37 PM
Souderton
Taylor Offline
Taylor  Offline
Souderton
there's a nice 454CI R5P7 for sale attaced is the Build sheet .
Biggest one I've seen was a 425ci , 4.224 bore and 3.795 stroke My uncle had it on the dyno at his old work , some where in the 900hp range 650 Tq ,
Re: NASCAR Engines?? [Re: Taylor] #2889051
02/16/21 09:15 AM
02/16/21 09:15 AM
an8sec70cuda Offline
A local chassis builder and friend of mine put one in a light weight backhalf Duster years ago. It ran 5.40s in the 1/8 IIRC. I remember him talking about how they didn't do much to it except for a cam change (going off memory here) and it ran really well for what it was. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
