Fan Belts #2888653
02/15/21 12:14 PM
02/15/21 12:14 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
69 Charger 440. Currently have the A/C comp in the car so both belts are running across comp, alt and the crank. The fan, ps and crank are a seperate belt. If I eliminate the comp, where do I run the shorter belts, alt and crank? Seems like they will rub the water pump. I do not have an idler pulley. I do have the belt pulley from the 400 that took the slack out of the long travel on the dual belts.
Grandma always said I had "hands of gold"!
Re: Fan Belts [Re: CHRGR69] #2889018
02/16/21 02:38 AM
02/16/21 02:38 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
You would need the pulleys and brackets for a non a/c setup.
