70 Charger door panel uppers #2888417
02/14/21 09:26 PM
02/14/21 09:26 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Putting a new interior in my Charger (needs it). How do the upper portions of the door panels come off? I've got the screws out, but they're not budging. Shop manual no help, but it shows two pins- does the panel come straight out, or up, or up and out? I'm just trying not to break anything I don't have to.
Re: 70 Charger door panel uppers [Re: ackpht] #2888422
02/14/21 09:37 PM
02/14/21 09:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Once any visible screws are out the bottoms pull out They have clips just like the lower panels. Once popped out they lift up off the door shell.
Re: 70 Charger door panel uppers [Re: NITROUSN] #2888451
02/14/21 10:25 PM
02/14/21 10:25 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Thanks- will give it a try.
Re: 70 Charger door panel uppers [Re: ackpht] #2888613
02/15/21 11:35 AM
02/15/21 11:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Are you talking about the padded uppers? Not all 70's had them. If you have an XH car there is no upper to remove.
Coming soon!!!!
Re: 70 Charger door panel uppers [Re: Mr.Yuck] #2888824
02/15/21 05:01 PM
02/15/21 05:01 PM
Morgan Hill, CA
ackpht Offline OP
ackpht  Offline OP
Morgan Hill, CA
Yeah, the padded upper. Got it off no problem, just took a little more screwdriver... wrench
Re: 70 Charger door panel uppers [Re: ackpht] #2888874
02/15/21 06:41 PM
02/15/21 06:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
A 90 degree trim tool works pretty good on leveraging them out.
